Question about Video Game Consoles & Games
I have a never used pet safe rf-1010 that keeps beeping i checked continuity and wire is not broken please help
Posted by Phillip J Hibbard on
How to set the collar of a Petafe in ground fence.
1st you have to hold down the little black button on the collar, when it flashes at you release the button.
-Then press the button again and count the # of flashes.
-Keep pressing the button until you get it set to the desired flashes related to the setting you want to use.
-1 flash- audible correction with no shock.
-2 flashes audible correction with low shock.
-3 flashes audible correction with high shock.
It is always recommended to start with the low shock , if using shock setting, then move to higher setting if needed. Most larger dogs require a high shock setting, I have a yellow lab and use the high setting for him. Hope this helps.
Feb 23, 2015 | PetSafe Pet Safe In-Ground Stubborn Dog...
How doI stop my motorola ME4067 cordless phone from beeping?
For Baby/Home/Pet Monitors, Cordless/Corded Phones, Digital Photo Frames
1-888-331-3383
Mon-Fri 7:00AM-7:00PM CST
Jul 10, 2014 | Motorola Lands Phones
How do I determine if my pet has fleas?
You need to thoroughly examine your pet's skin and haircoat. Fleas are reddish-brown and very fast, so you have to look closely. There may only be telltale flea dirt (flea *****),. Take a moist, white paper towel and rub it on the area. When moist, flea dirt turns a red color.
May 13, 2012 | Pets - Others
Hi, Cadillac family.I keep blowing a 10 amp fuse for the fuel pump on my 1984 fleetwood brogham d elegance. wires in the driver side tail fin have been chewed by a family pet. put the caddy in the...
Hi, the fuel pump wires are not in the tail fin. Check to see if the pet might have got under the car and chewed. Your diagram is below. Please let me know if you have questions, and thanks for using Fixya.
Mar 16, 2011 | 1984 Cadillac Fleetwood
My playstation 3 will not load up the green light comes on but nothing happen a few minutes later it says 'cannot start correct hard disk was not found' can anyone help on how to fix or how to recover my...
Try this, but keep in mind that one of the options wipes all your data.
These should be safe to use, and 'should' keep your data.
  • Restore Default Settings
  • Restore File System
  • Rebuild Database
  • Step 1: Turn off the PLAYSTATION 3 by holding the Power button on the front of the unit till the Power light is red.
    Step 2:
    1. Touch and hold the Power button, you will hear the first beep, meaning the PLAYSTATION 3 is powering on.
    2. Continue to hold the Power button and after about 5 seconds, you will hear a second beep, indicating the video reset.
    3. Continue to hold the Power button and after about another 5 seconds you will hear a third beep and the system will power off (Power light is red).
    Step 3:
    1. Touch and hold the Power button, you will hear the first beep, again for the PLAYSTATION 3 to power on.
    2. Continue to hold the Power button and after about 5 seconds, you will hear a second beep for video reset.
    3. Continue to hold the Power button and after about another 5 seconds you will hear a quick double beep. At that point release the Power button. If you succeeded in activating Safe Mode, you will see a message on the screen saying, "Connect the controller using a USB cable and then press the PS button."
    4. Connect a USB cable to the controller and the PLAYSTATION 3 and press the PS button to enter Safe Mode.
    5. Then you will see the Safe Mode menu.
    Step 4: We recommending performing the safe mode options in the following order until one of the options works for you. If one of the options work, do not continue onto the other options.
    1. Restore Default Settings
    2. Restore File System
    3. Rebuild Database
    4. Restore PS3 System
    Oct 04, 2009 | Sony Video Game Consoles & Games
    My kiddie carbon monoxide detector keeps giveing 4 quick beeps w/ a 5 sec silence as if a problem exists. However, when I take it outside into the fresh air, the problem continues. I believe this started...
    May need battery replacement. These beep when it needs change of battery. Could also be broken, i had one that kept beeping on and off no matter how many batterries i changed. These break easy when dropped. Check if it has a warranty maybe it can be replaced.
    Aug 17, 2009 | Kidde Nighthawk Combo Gas/co Detector
    Video Game Consoles & Games Logo
    148 people viewed this question
    Top Video Game Consoles & Games Experts
    Muntejaya Ginting
    Muntejaya Ginting
    Marvin
    Marvin
    Tom Chichester
    Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
