Dell e1505 would not boot. when I plugged in a power source it shuts off the green lights.
HI, CHECK THE MEMORY CARD AND VIDEO CARD, FIRST UNPLUG THE PC REMOVE TWO SCREWS FROM THE RIGHT COVER SLIDE BACK THE COVER, YOU WILL SEE ON THE RIGHT UPPER SIDE OF THE MOTHER BOARD ONE OR TWO RECTANGLE LONG BOARD/CARD THAT IS MEMORY CARD, ON BOTH END IS A LOCKING TAB, BEFORE YOU TOUCH THE CARD ON LEFT HAND TOUCH THE MAIN FRAME OF THE PC THEN PUSH BACK THE LOCKING TABS TOWARD TO THE MAIN BOARD THE MEMORY BOARD/CARD WILL POP OUT. CLEAN THE CONTACTS OF THE MEMORY BOARD /CARD, REINSTALL IT BACK, IF THE PC DID NOT TURN ON .YOU NEED A POWER SUPPLY TO BE REPLACE.
MAKE SURE YOU BUY THE SAME POWER SUPPLY YOU HAVE ON PC. YOU CAN SEE THERE IS A LABEL ON THE POWER SUPPLY WHAT IS THE WATTAGE. HOPING THAT THIS MIGHT HELP YOU SOLVE THE PROBLEM.
HH
Hi I repair 7 of those power supply and I can tell you exactly wrong cause this are always be drop lot of times and it will stop charging your battery and or will not give no power to your laptop. The problen is the motherboard is fried or shorted. In that power supply there is a little transformer that soldered are all broken off and not connecting anymore. just order or buy a new one your laptop is fine it will be working again.
Thanks for the response byte guy. I don't believe its a problem with the battery. I tried using other power adapters and the green light goes off when plugged into the pc. I believe its a shortage on the mother board.
This was another response i got.
Take out the battery and try it. Are you using the correct power supply?
