Question about Saitek Video Game Consoles & Games
Saitek X45 joystick firmware drivers - Saitek Video Game Consoles & Games
Posted by Gerald Deitch on
2 Related Answers
Anonymous
  • 259 Answers
SOURCE: Windows 98 drivers for Saitek AV8R joystick
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} You may have to install or update drivers Most of the drivers/software I get are from a web site driverguide.com you need to fill out a free registration then search for the driver you need download it in a format you can use install it and then most times reboot the computer
Please leave Comment or Rate answer for me to improve in the future
Posted on Jan 26, 2009
Anonymous
  • 43 Answers
SOURCE: broken wire between saitek x45 joystick and
ditto hapend to me, call there support line or go to there webpage and get a replacement if under warranty if not the cord is around 5$ CAN.
Posted on Jan 01, 2010
My Saitek ST90 joystick doesn't work on up/down, right/left, but fire buttons work. I'm using windows 7 home premium 64bit
You may need to update/roll back your driver
  1. go to device manager
  2. select the saitek st90
  3. click update
  4. if no updates are found click roll back
Not working with windows 7
You can download the driver software from the Saitek website, here's the link http://www.saitek.com/uk/down/drivers.php
Just select Joystick in the first drop down box, then your version of windows 7 (32 or 64 bit) then just follow the instructions to download your drive.
Install the driver before you plug in yours joystick (the driver will more than likely ask you to plug it in at some point in the install process).
I hope this help you out.
2helpful
An oven heating control system. schematic diagram? block diagram? the feedback operation in the control system? control objective? five basic element of the control system?
schematic diagram?
block diagram?
control objective?
3helpful
Broken wire between saitek x45 joystick and throttle boxes
Thrust in FSX won't reach higher than 55% even with lever at full
This is either a calibration error, or a faulty stick. Nothing else can cause this. make sure you have the latest drivers installed or one's that it came with. Some operating systems will see the stick and load generic drivers which sort of work, but not fully. Always use the manufacturers drivers and install it using the correct route as in the installation as there are ways to install drivers that do not register them properly and you think they are installed but are not. Good luck with it.
Saitek x45 throttle gameport connector needs to be rewired
Sorry to say this so vaguely, but Google it. I am positive that Google will have the answer. Type in the model number, name, and what you need for it and you will be satisfied.
2helpful
2answers
Saitek X52 Joystick
Try deleting the drivers for the joystick, visit Saitek website get latest drivers and re-install the joystick, might fix the problem.
SAITEK ST290 JOYSTICK USB disc
you can download from www.drivers.softpedia.com for free.
yes it is compatible with vista.
you may try for: www.opendrivers.com
Video Game Consoles & Games Logo
Top Saitek Video Game Consoles & Games Experts
Ekse
 TE5LA
TE5LA
ADMIN Canada
ADMIN Canada
Are you a Saitek Video Game Console and Game Expert? Answer questions, earn points and help others
