Ice-maker thawing - refreezing into block Our 18 year old side-by-side Sub-Zero has this problem about once a week: Makes ice cubes that fill the drawer, then the cubes thaw, melt, and refreeze into a block of ice. Meanwhile the rest of the freezer works fine; no other thawing.
But if the defroster is having a problem, wouldn't this affect the entire freezer? Nothing else is thawing except the ice in the icemaker.But if the defroster is having a problem, wouldn't this affect the entire freezer? Nothing else is thawing except the ice in the icemaker.
AnonymousMar 13, 2014
can I refreeze a refrigerated thawed pot roastcan I refreeze a refrigerated thawed pot roast
AnonymousMar 23, 2014
I accidentally set out frozen tuna steaks. Can I refreeze them after they have thawed outI accidentally set out frozen tuna steaks. Can I refreeze them after they have thawed out
AnonymousMar 29, 2014
can I refreeze thawed out pork ribscan I refreeze thawed out pork ribs
You can't post conmments that contain an email address.
i don't know how old your fridge is but on older ge's if the evap fan motor was bad they wanted you to also change out the motor board.first thing unplug it,look at the board the newest boards have 7 relays on them,if yours doesn't i would change the board out,this is what powers everything in this machine,compressor,fans everything,so if i had this issue i would change out the board or it sounds like you could have a bad compressor but that would be new fridge time, part wr55x10942 now the newest board is wr55x10942p i haven't seen one of those yet but i looked up a fridge yesterday and saw that so they made more changes to this board.good luck
You can do that, but if it does it again you will need to order a new inlet valve. This where your water line is connected in the back. Rate me if I helped.
Good day, In most cases it is the water valve that feeds water to the ice maker well. The valve is energized by the ice maker to fill for 7 seconds and then shut off promptly. The valve will many times dribble water into the well after shut off, causing an overflow problem. The fix is a new water valve kit. The only other possibility is the freezer temperature going above freezing from time to time, but is a rare problem.
No, Sub Zero does not have an icemaker switch to turn it off and on. How old is your unit? Icemakers can last for 3 years and sometimes they can go out after 18 months.
I believe it's your ice maker. We are factory authorized Sub Zero and can get the correct part out to you right away.
remove cube tray from ice maker. clean with limeaway adn rinse. Spray with a light coating of PAM cooking spray. wipe dry and reinstall. be careful not to damage the sensor ( in center of tray)
This issue occurs if your Ice Maker is not clean or have dust particals inside, follow the below steps in order to clean it properly:
Step 1
Lift the power bar located above the ice maker storage tray.
Step 2
Unplug the refrigerator.
Step 3
Allow the refrigerator and freezer to defrost. This will melt any large blocks of ice that have accumulated in the ice maker.
Clean the Ice Machine
Step 1
Remove the ice machine storage tray.
Step 2
Dump any water in the ice machine storage tray.
Step 3
Wash the ice machine storage tray using warm, soapy water. Rinse and allow to dry completely.
Step 4
Sanitize the lines of the ice maker. Consult your manufacturer's directions for steps to do this, because it's not available on all models.
Reassemble the Ice Maker
Step 1
Replace the ice machine storage tray.
Step 2
Plug the refrigerator into the outlet to restore power.
Step 3
Lower the internal power bar located just above the ice machine storage tray. This allows the ice machine to make new ice.
Ice maker was intermittent at best - ice was often just a shell. After
two failures to correct we had the ice maker (a Whirlpool - on a Sub
Zero - Go figure) replaced. Then the paddle that detects the ice level
broke. Next step a new GE.
Check water turned on. check ice button switch turned on in fridge. remove juice storage, ice container in freezer, check ice bucket full white plastic flapper to make sure not stuck on a white peg at top. flapper must hang down and be freely movable to signal ice maker to keep busy. If up high will turn off ice maker. Lots of other parts especially heater circuits involved also: fill tube supply heater not working then frozen supply line then no ice. Look for wiring diagram in ziplock behind compressor grille. can order parts at repairclinic.com. logical design, layout, easy to get to sensors, heaters. makes sense if look at it long enough.
