Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer will not spin out water, shows F02, already checked the hose for kinks and/or clogs?
Posted by 2363me40 on
  • 2363me40 Aug 13, 2009
    how and where on the washer is the pump located?
Michael Masters
  • 6,784 Answers
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Posted on Aug 13, 2009
  • Michael Masters
    Michael Masters Aug 13, 2009
    The water pump recirculates water during the wash cycle and pumps it out for the spin cycle. Some washers use the recirculation to mix and distribute add-ins like bleach or fabric softener. In some models the spin cycle starts while the water is still in the tub; others drain first before the spin cycle starts.
    For the the initial filling of the tub, the pump is not involved. Filling the tub is the job of the water inlet valve. The rinse cycle is also done with fresh water supplied by the inlet valve, although the water pump may be running simultaneously to remove the water while it is being added.
    A blocked or malfunctioning water pump can be responsible for many different washer problems; see our diagnostic page for the list. Note that while a problem may seem to be related to the pump, the problem may really lie in one of the connecting hoses. Each of the hoses that connects to the water pump should also be inspected. A blockage may occur anywhere in the water's pathway.
    There are two types of pumps; direct drive and belt drive. The direct drive is mounted directly to the motor, the belt drive is mounted to the chassis. The direct drive style can be opened for complete inspection while belt drive models may or may not be designed to be opened. You can however, still remove the hoses and inspect the ports for a blockage. Inspecting the pump is fairly easy to do, but you will most likely have to open the washer's cabinet.
    Typically one of three problems occur with the pump. The first is a blockage in the pump, often from small items like a sock. The second possibility is that the impeller blades become broken or worn down and cannot move water efficiently. Finally, in belt drive models, if the belt is loose or broken it does not turn the pump.
    Locate the pump(((which is inside the washer on the lower left or right hand side))), it will have two, three or four hoses. Label each hose and where it connects. The hoses should each have a wire clamp or a hose clamp with a screw. Pinch the wire tabs together with pliers and wiggle the clamp farther up the hose. Screw style hose clamps are simply loosened by turning the screw, then slide the clamp up the hose. Now remove the hose from the port.
    Direct drive pumps have metal clips that hold the cover plate unto the pump assembly. Use a screwdriver to pry up the clips and remove the cover. Pull off the pump's impeller unit and inspect for damage.
    Belt drive pumps vary and may or may not be designed to open for repair. Examine the pump to determine whether it can be opened. If it cannot be opened the look into the ports for any blockage.
George Agios
    Sergeant:
  • 220 Answers
Change the belt of the motor.
Posted on Aug 08, 2012
F02 error Pump Filter hoses all ok. Whirlpool duet front load.
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F02
this is a long drain code on the whirlpool washers. when the drain time exceeds 8 minutes, the water valves turn offf and the f2 code appearsr.
push the pause/cancel key 2 times to clear it.
Around 4 minutes the sud code will show, then 4 minutes after that the f2 will show.
1)Inspect the drain hose for clogs or kinks.
2)Check the electrical connections to the pump and listen to see if u hear the pump running.
3)Check the drain pump filter for debri.
4)And finally if what i said previosly does not work then u must replace the pump.
Jan 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F02 shows on my washer...what does this mean
The F02 Code usually means the washer machine can't drain the water. Usually caused by a failure of the drain pump or a clog in the drain hose.
Dec 20, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool Duet washer... code flashes saying 02 F ... Help!
F-02(Long Drain)
HI. This code is an indication of a failed drain cycle(Long Drain Issue). Kindly, follow the steps below to address this issue further.
If the drain time exceeds eight minutes, the water valves are turned off and "F02" is flashed.
Press PAUSE/CANCEL two times to clear the display.
NOTE: After four minutes the "Sud" error will be displayed, then four minutes later the "F02" error code will be displayed..
Possible Causes / Procedure
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Dec 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Why won't the washing machine spin out. It keeps blinking F 02? What does that mean?
Check the drain hose make sure its not plugged or kinked
Check the electrical conection to the pump
Check drain pump filter for foreign objects
Oct 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Mdl GHW9150PWO Washer stops
Potential Causes
Oct 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My duet washer has an error code f20...what does this means?
not enough water going to the machine..
“Spin” and “Wash” (HT “Rinse” and “Cycle
Complete”) illuminated or “F20” on display
(Water Inlet Problem—no water or insufficient
water supply)
Select PAUSE/CANCEL twice to cancel the cycle
Check the following:
Are water faucets completely turned on?
Are screens at inlet hose connection to washer
clogged? Are water inlet hoses kinked?
Are water inlet hoses frozen?
Aug 19, 2009 | Whirlpool Duet WFW9550 Washer
Whirlpool Duet ----"SUD" and "F02" code
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE [email protected]#$%
Aug 05, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Model GHW9150PW0 shows code F02. The washer did nor complete the spin cycle and water was left in the tub. How do I get access to the pump. How do I remove the panels. Thank you
Potential Causes
Jun 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Flashing F2
“F02” (Drain Problem)
Select PAUSE/CANCEL twice to cancel the cycle. Unplug
Is the drain hose kinked?
Is the drain hose frozen?
Is the drain hose clogged?
Is the drain hose more than 96" (2.4 m) above the floor?
After running this check list, plug back up and try a complete cycle using cold water and no detergent. Sudding can mimic a drainage issue as well. make sure you are using the correct HE detergent to prevent over sudding.
Feb 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
1,262 people viewed this question
Marvin
Marvin
Michael Thomas
Michael Thomas
