A couple days ago things were alittle bit blurry and now all i get out of it is sounds, no video no picture. i have no idea what it could be, it took every cord out of the system and plugged it back in....... Nothing. Then i moved to a different tv........ Nothing.
First try removing any accessories (for eg HD drive, hard drive or network adaptor) from the console and turn on 360. Plug each device back in one by one and turn on to check which device possibly causing the problem.
You should also try using another 360 AV cable sometimes this is the culprit.
If the above methods made no difference then the Xbox 360 might be overheating and which will eventually lead to RROD (Red Ring Of Death - 3 red ligthts) or E74 error message (1 red light) indicating repair.
You can buy the repair kit off ebay from £4 - £7 and carry out the repairs yourself with plenty of Youtube videos on the net just google it or if dont dont feel confident i can repair for you.
If this helps please vote...thankyou!
Hey!
I had the same problem - there might not be anything wrong. I moved my Xbox360 from my nicer 1080p tv to a 480p tv and it woudln't display an image because I set my xbox to output at the full 1080p HD setting. Try resetting your xbox to the default system settings or use the regular AV composite cables ( red yellow white) instead of the component ones ( 4 cables )
Hope that helps!
Plug the color wires in tight baby
