Question about Sony Televison & Video
Turns on and off
Turn the tv on and then it will turn off by itself then turn back on then turn off
    Scholar:
  • 80 Answers
If your TV turns off by itself, first check whether or not it has a built-in sleep timer by consulting the instruction manual of the TV in the Manuals/Specs/Warranty section of the Sony® eSupport Web site. If the TV does not have a sleep timer, or the timer is not set to turn the TV off, service may be required to resolve the issue.
Posted on Aug 14, 2009
TV turns off and immediately on again, by itself.
sounds like a defective str power regulator ic .......but my advice get a tech to resolder all the pins at the power suppy board area, there may be some open pins that triggers the on and off episodes
Jul 18, 2013 | Televison & Video
TV turns itself off after about 5 minutes (green light remains on). I can turn off the TV and turn it back on immediately, however, the TV turns itself back off after a few minutes. It started turning off...
Check and make sure your fans are working and there is sufficiant cooling to the back of the set. Sounds like it is overheating and going into protection mode.
May 04, 2011 | Mitsubishi WS-65513 65" Rear Projection...
Freezes turns white then turns off then back on
IF YOUR IMAGE IS ALL WHITE YOUR LOGIC BOARD IS DEFECT BUT IM SAD TO SAY DO NOT REPLACE THE LOGIC IT WILL ONLY TEMPORARLY SOLVE THE PROBLEM THE PANEL IS OVERLOADING THE LOGIC BOARD PANEL IS BAD
Apr 24, 2010 | Samsung LN-S4041D 40 in. LCD HDTV
Plasma TV turns off by itself-won't sty on for
when i turn my 32 inch VIVIO plasma tv on it turns pff by itself. i want to know why this is happening
Dec 07, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Philips Magnavox TV turns itself off and on
I had a problem that has not been fixed that i had put glass cleaner on my tv and every time i turn it off it comes back on sooo i do not have a solution so i need more and cheap ways to fix my tv.
p.s. i am 9
May 19, 2009 | Philips Magnavox 32PS55S 32" TV
Turns off by itself!!!
The flyback transformer are damaged .
May 26, 2008 | RCA TruFlat 27F520T 27" TV
Mitsubishi WS 65513 turns itself off
Probable four bad caps in DM module = 1000mf/25v
Common repair for qualified Mits tech...........T.
Nov 11, 2007 | Mitsubishi WS-65513 65" Rear Projection...
TV has green sceen and turns off by itself
you have the famous zenith shorted picture tube
Aug 07, 2006 | Zenith C27V22 27" TV
Televison & Video Logo
2,151 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
