Question about Canon PIXMA MP210 Photo All-In-One Printer
I get an E 6 code in display
Printer is not responding. Hope ou can help me out. Thanks Chris
Posted by cab123124 on
Anonymous
    President:
  • 2,049 Answers
According to your owner manual from Canon, it says...
Ink has run out.
Replace the ink cartridge and close the Scanning Unit (Printer Cover).
If printing is in progress and you want to continue printing, press the Stop/Reset button for at least 5 seconds with the ink cartridge installed. Then printing can continue under the ink out condition.
The function for detecting the remaining ink level will be disabled.
Replace the empty ink cartridge immediately after the printing. The resulting print quality is not satisfactory, if printing is continued under the ink out condition.
Posted on Aug 13, 2009
Anonymous
    Problem Solver:
  • 13 Answers
I think there is a problem with the print head.
Error code E6 has this meaning:
E6 Not detecting the print head Install the print head or replace it
according to this page.
So, I would take the print head out and put it in again. Maybe the reason is a loose connection.
2answers
Looking for Printer drivers (Canon MF4320-4350)
if you are lost your driver to download your device suitable driver use http://devid.info step to download driver my computer manage, device manager, property on device whose driver are not found copy device id code displayed on example above site copy it and use to download suitable device driver after download extract and go to update driver whose device are installed enjoy THIS TIPS
Door lock stuck
Hi etmscholten,
Please check the door latch components. The F9 error code appears when there's a problem with the door latch.
Hope it helps.
Thank you for using FixYa.
Display problem
GO into the BIOS setup routine and make sure that the "onboard video" if it has any ,is set to off. Malke sure that ou have the monitor attached to the video card and not the :onboard: one. Did you install the softweare and driver for the video card?
To receive further help, please  give us the make and model of the video card. Thanks
2answers
Error code 4 flashing orange - code 5c00
Hi Chris,
Error code 5c00 (flash in orange /green 4 times) indicates that purge unit has broken so that the printhead is locked down when initializing process performed. Sorry I have to say that no first aid for this problem unless you bring it to nearest service centre for part replacement. Hope this information helpful for you.
Regards,
Source:
Canon Inkjet Forum
Lost handbook - How do I photo Copy a document?
Here ou will find a copy of the Users Guide. Hope this helps. Please rate this information.
Thanks
No ink impresion after cleaning the waste in pads....
Hope it will work
Reset ip2000
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
3helpful
Cannon W6400 Printer
Unplug printer for about an hour, should power back on after this period, if not remove panel from rear of machine and unpug the power supply from the PCB board. Reconnect and the machine will work again.
Chris
Sharp AR161 Copier Printer Problem
Reinstall your printer in to your computer and try the test print.
5helpful
5answers
SCAN,COPY,FAX PROBLEM
Issue An 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved. If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.     Here is a manual if you dont already have one.   http://h10032.www1.hp.com/ctg/Manual/c00486336.pdf
Canon PIXMA MP210 Photo All-In-One Printer Logo
old marine
old marine
Ekse
