Question about Blaupunkt Car Audio & Video
Blaupunkt code required BP237547048138 7642 375 316
Posted by Kamlesh Ruparelia on
I have a Holden Astra model 2002 And after replacing the battery I tried to turn the Blaupunkt 520 radio back on by using my code. Unfortunately this code is not recognised anymore. Typed in 1111 and the...
The original radio code is required and this can be retreived from the serial number, for a Blaupunkt radio this number will start with 'BP' send it to this link and pay a small fee: Car radio codes in Uxbridge London Gumtree
Nov 20, 2017 | Blaupunkt Car Audio & Video
Can you give me the radio code for blaupunkt
The radio SERIAL NUMBER is required for a code
First remove the radio from the dashboard.
Then post the radio make+model plus all the letters+numbers on any labels,barcodes or stamped in the metal casing.
This information can then be used to see if a code can be calculated
Jul 03, 2011 | Blaupunkt Nashville DAB35 CD Player
Need an unlock code for my blaupunkt cheyenne cm 42 9 404 230 253, BP0253n1516750 0 9 1 6 1 4
I think this is an old Blaupunkt where the code cannot be calculated using the serial Number.
It will require specialist advice . Try asking here for free advice....CLICK HERE Mention FixYa
Jul 01, 2011 | Blaupunkt Car Audio & Video
Need a code to unlock our blaupunkt car 2003 car radio in a vauxhall agila
The radio SERIAL NUMBER is required for a code First remove theradio from the dashboard. Then post the radiomake+model plus all the letters+numbers on any labels,barcodes or stamped inthe metal casing. This information canthen be used to see if a code can be calculated
Apr 23, 2011 | Car Audio & Video
Citroen/Blaupunkt radio unlocked but won't stop beeping
VIN coded radio.
Radio will require coding to your car`s management+security system.
Contact your Citroen Dealer or Radio Decoding Business
May 29, 2010 | Car Audio & Video
Blaupunkt malibu cr42 reset security code
These are an older Blaupunkt radio that uses a wired code system and will require specialist attention.
Try here
ukbookshelf.co.uk
as they may be able to help
Mention FixYa
Apr 23, 2010 | Car Audio & Video
I have a blaupunkt chicago rcm 169 radio how
According to my database the BP Chicago RCM169 uses a SMARTCARD and does not require a code.
No free solution
Available from your Main Dealer or a Decoding Service only
Nov 20, 2009 | Blaupunkt Car Audio & Video
What button do I press after inserting blaupunkt radio code on my Valencia CD52 model? I pressed the ok button last time and I got the message code locked.
Are you sure you require a code as my database says that this BP VALENCIA CD52 is a NON CODED model.
If not , then find your Blaupunkt Radio code entry instructions here
http://www.radio-code.co.uk/code-entry-help-Blaupunkt.htm
Nov 07, 2009 | Blaupunkt IDC-A09 5-Disc CD Changer
Car Audio & Video Logo
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Sheldon Dedek
Tom Chichester
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
