Question about Shredder Office Equipment & Supplies
I need a gear for a 110 Fellows Power shredder
Posted by Barrie LeBlond on
5 Related Answers
Anonymous
  • 102 Answers
SOURCE: Fellows sb-95c shredder parts???
Call Fellowes Customer Service at 1-800-945-4545
Posted on Feb 23, 2008
Anonymous
  • 102 Answers
SOURCE: Shredder
your best bet will be to call Fellowes at 1-800-945-4545 we will be more than happy to assist you.
Posted on Apr 01, 2008
Edward
  • 105 Answers
SOURCE: I have a fellows 420 cc power shredder that will
if ther are no red warning lights lit, then you will have to replace the auto feed senors or the main power switch.
Posted on May 14, 2009
Anonymous
SOURCE: Fellows T7CM Shredder
Make sure you remove all five screws--there's one hidden under the sticker on the underside of the shredding unit.
Posted on Mar 16, 2010
1alexh
Alex Howard
  • 484 Answers
SOURCE: mY FELLOWS GD1200 SHREDDER IS REALLY JAMMED WITH
First, UNPLUG IT!
2 - Then remove the top. shredding part and flip it over.
3 - Carefully, with your fingers, not a pliers, remove all the paper bits and pieces from the underside of the shredder.
4 - Turn it back to right side up, and place it on the basket as it should be positioned, then plug it in and turn it on in REVERSE first.
5 - Once it starts, let it run until it stops; it should only be a couple of seconds.
6 - Turn the direction back to normal, and see if it will run that way.
Good luck,
-a.
Posted on Apr 22, 2010
Parts for fellows sb-97cs
Check eBay for parts or Craigslist for a shredder you can cannibalize. Sometimes Fellowes can give you the part number which can help you search.
Jul 03, 2014 | Fellowes Manufacturing Powershred SB-97CS...
NEED TO REPLACE PLASTIC/VYNAL GEARS FOR A P55C FELLOWS SHREDDER
Have you owned it for less than a year? The warranty on all parts is one year from purchase and 3 on the blades.
If its out of warranty then you have to choose between trying to find parts or replacing the whole unit.
You can buy a refurbished one from Fellows for $45.00 at this link.
Refurbished Shredder
I doubt you are going to find parts for your shredder but even if you could I suspect the will cost about half of what the whole refurbished one costs
Oct 16, 2013 | Office Equipment & Supplies
Need a new (3 way) switch for my fellows ps 60cc shredder where can I buy one from...can you send me a email address?
fellows # 800-955-0959 they take credit card.
Hope this helps leave feedback. Have a nice day
May 15, 2010 | Office Equipment & Supplies
My Fellowes ps-40 will not shred. The motor is
you have some shredded gears. i don't think fellows has replacement parts for their personal shredder line.
Nov 15, 2009 | Fellowes 3011001 Shredder
Paper stuck in the Fellows Paper Shredder
  1. Remove Shredder from paper catcher bin
  2. Remove shredder cover from shredding mechanism assemble (approx. 6 screws on bottom of cover)
  3. Separate shredding mechanism from bottom cover (may have disconnect circuit board from assembly and other wiring from switches , sensors, etc,)
  4. Remove motor gear cover (approx. 4 screws)
  5. Separate shedder main drive gear from motor step up gear by pulling gear out
  6. Turn shredder mechanism up side down to access the cutting blades
  7. Use an adjustable wrench to turn the main drive gear to see stuck paper
  8. Use a needle noise pliers to remove paper shreds
  9. Repeat step 7 and 8 until all shreds are remove and cutting mechanism move smoothly
  10. Reassembly before testing shredder
  11. If you remove only some of the shreds, the motor may seize up and strip the plastic gears from step up gear.
Feb 09, 2009 | Fellowes DM8C Cross-Cut Shredder
Office max paper shredder
You need to find out who made the shreddr, Fellows, GBC, etc. parts are available to brand name machines...
Jun 03, 2008 | Office Equipment & Supplies
Fellows ps60c-2
took schreder apart: The plastic driven gear it striped is that gear serviced
Apr 01, 2008 | Fellowes PS60C-2 Shredder
Top Shredder Office Equipment & Supplies Experts
Ross Keen
gbob59
Marvin
Marvin
Are you a Shredder Office Equipment and Supply Expert? Answer questions, earn points and help others
