I was also facing same problem like you. My HP laptop is restarting after sometime. I think your laptop need a hardware engineer to fix it properly. Because, he can solve this problem easily.
Hopefully, you did not try to put the memory card in while the pc was on and you ground yourself to the pc first. You would be amaze how quick it is to short your motherboard with static shock. Try taking the memory card out and power on your pc. If it power on, you may need to use a different memory card or make sure it is completely seated in the slot. If the pc don't power on, you may have shorted your board and it wil need to be replaced.
Good Luck
C2Solutions
