Motorola Mobility MOTO W755 Cellular Phone Logo
Posted on Aug 13, 2009
The keypad on my Motorola W755 cell phone is inoperative except for the power on/off key.you can still receive incoming calls by flipping open the phone.
Anonymous
Level 1:
  • Contributor 35 Answers
  • Posted on Aug 18, 2009
Anonymous
Contributor
Level 1:
Answers
35
Questions
Helped
8611
Points
55
Check phone might be liquid ingressed to clean,if not replace keypad.
1helpful
How do you lock the keys on a motorola w755
with the flip down, press and hold the left side button till you see 'keys locked' on the front screen.
1helpful
2answers
Keys not working
dont worry.its only the key pard problem.you need to replace the key pad and dont forget to ask the repirer to clean the circut board.avoid hard use of key pad.take care
It won't dial
Check phone liquid ingress keypad connector to main board,swap another flip,if ok,replace keypad or display.
My keypad wont work except for on/off wotn work
may be your keypad might have worn out or your phonse's software might be under problem. try replacing the keypad in your phone and check it out. it it does not work still then remove the user serviceable parts like panels batteries and clean then using a clean damp cotton cloth.be sure the cloth is not much wet to affect the ic's of the phone.it this also does not work get a pro to attend your phone's software problem,
2answers
My e815 keypad seems dead - power button is the only one working
Well, the phone is done with.
I dont understand why but most "motos"
are like that.
Sorry I couldn't help much...
Alarm has stopped working on my Motorola W755 cell phone. Sounds work fine on incoming calls.
Try restore factory settings.Menu/settings/initial setup/restore factory settings enter 1234 ok.
should be ok.
1helpful
How to I set the number of rings before it goes to voice mail on a Motorola MOTO W755?
You can't.
An incoming cell phone call being transferred to voicemail is not controlled by the phone. It is a function of the cellular system.
Only the End key works
download the set of programs from that link i sent you, if u hav installed drivers for ur v3 as yet, jus plug in the cable n folow the prompts n select the folder called p2k drivers, afer that restart ur pc, install rds lite 2.4 n plug ur fone back in n browse for the small in the the key pad folder n flash ur fone... that shud fix ur keypad issue
http://www.4shared.com/file/40625107/d1513354/key_pad_fix.html
KEYPAD???
Usually this means that you need to take it to a repair shop to have the keypad replaced but truthfuly it would be cheaper just to get a new phone. Hope this helps =)
3answers
Motorola v3x
Hi There, If this phone is brand new it is faulty and should be returned to seller. This problem usualyy occurs when u have a faulty flex cable either on the screen or the entire keypad assembly. One of these would need to be replaced by a repair tech for v3 phones.Hope this helps. Sam !
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
