Master
- Posted on Aug 13, 2009
Re: Can't find "cartridge error 50C" in my Dell owner's...
Cartridge Error 50C
Your print cartridge has shorted.
- Power off your All-in-One and unplug it.
- Plug in your All-in-One again and turn it on.
- Uninstall and then reinstall your cartridges.
- If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Cartridge Error
Complete the following instructions:
- Power off your All-in-One.
- Use both hands to lift up the scanner unit until the scanner support holds it open.
- Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
- Remove the color print cartridge.
- Lower the scanner unit until it is completely closed.
- If the error message reappears, replace the black print cartridge with a new print cartridge.
If it does not repeat steps 1-3 and then go to step 7.
- Reinstall the color cartridge and remove the black print cartridge.
- If the error message occurs again, replace the color cartridge.
- If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
- If you receive the error message again, replace both cartridges.
