Question about Panasonic DMC-FX33 Silver Digital Camera
Lumix DMC-FX33 turns itself off
We have an 18 month old Lumix DMC-FX33 and it turns itself off with an error message immediately after turning it on.
The error message says to turn the camera off and on, but that doesn't help.
Any suggestions?
Posted by chriswaco2 on
Syzys
    Sergeant:
  • Panasonic Expert
  • 361 Answers
Try turning off the camera, removing the battery, putting it back in and turning on the camera. If that doesn't help either, try checking the user manual for details:
Panasonic DMC FX33 manual
Posted on Jan 09, 2015
Ty Price
    Brigadier General:
  • 11,967 Answers
The message appears when force has been applied to the lens. You will probably need service.
Posted on Aug 13, 2009
Flash is not working
Are you sure you turned it on in the camera settings? Try checking the user manual for information on how to turn on flash:
Feb 11, 2014 | Panasonic DMC-FX33 Silver Digital Camera
Flash not working on DMC fx33
Are you sure you enabled flash through the options? Check the user manual for any setting related to flash before considering having the camera serviced:
Feb 10, 2014 | Panasonic DMC-FX33 Silver Digital Camera
How do i reset lumix dmc-fx33
There is an entry for "reset" in the set-up menu.
Sep 29, 2011 | Panasonic Lumix DMC-FX33A Digital Camera
The DMC-FX33 doesn't take pictures except sometimes on iA mode
In most cases, the camera is beyond economic repair. If the camera is a few years old, buying a newer one is a better option. I'm seeing brand name 10 MP models NEW for $60. you might check online auction sites for used ones. I've picked up 5 MP ones for $5.
Jul 02, 2010 | Panasonic Lumix DMC-FX33A Digital Camera
Panasonic DMC-FX33 has operated perfectly for 3 + years. Suddenly, when turning on, camera displays message "Please turn camera off and then on again". Lens cluster 'twitches' but does not extend out....
Hello. If you suspect this is a lens problem ,I agree. I've had good results tapping the camera into the palm of my hand while its trying to open. Also try conecting your transfer cable to the camera and then press the power button, this keeps the viewing screen turned off sending full power to the lens mechanism. Lastly,and I should have mentioned it first,If you have a piece of exposed photo film,cut a small strip and work it in the gaps between the lens barrels to try to remove anything which may be stuck in there
builderdale
Jan 13, 2010 | Panasonic Lumix DMC-FX3 Digital Camera
Lumix FS-15 "System error (focus)"
I have the same issue with my 3 month old Lumix DMC FS15 plus it won't focus and gives the error message to "turn camera off and then on" This doesn't fix it.
Bottom line fix: Don't buy this camera again and don't recommend other buy it.
Sep 19, 2009 | Panasonic Lumix DMC-FZ28 Digital Camera
CAMERA UNIT IS PANASONIC LUMIX DMC-FX33 MENU
It may be that for the type of picture you are taking the mode - dial at the top of the camera is not compatible.
Try a couple of different modes by adjusting the dial to auto, etc.
Apr 22, 2009 | Panasonic Lumix DMC-FX33A Digital Camera
Mov to Avi software question
the best available editor is adobe premeir pro for video editing and for converstion you may use imToo application.
Dec 20, 2008 | Panasonic Lumix DMC-FX33A Digital Camera
Panasonic DMC-FX33 Silver Digital Camera Logo
Top Panasonic Cameras Experts
ENFORCER
deton8 von Splosion
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
