Need to assembly the drawers of a Upland Wooden Storage Bench by Wildon Home. It was a gift foe my daugther but the lost the instructions. I bought the bench on 11/13/2018 from Wayfair. Please help
SOURCE: setting the time on a bench watch
hi i had the same problem but i have just found the answer. hold the light button until it flash's 12 or 24, then press mode which will change you on to the time, date, ect then fiddle around with the start and reset button to toggle with the time and date. when your done with the time press light again.
Posted on Dec 22, 2008
SOURCE: Setting Bench Watch
Reset Instructions Bench. (BC0013BR)
Time and Location
If you hold in the light, start and the reset button for a few seconds a screen will appear with the 12h or 24 h clock setting and also the date and country.
Once you have that screen if you press the mode button it will move over the date and clock etc then you just press the reset button and start button to choose the date and time.
Once you have changed the date and time to the correct date press the light button, start button and reset button and it will save the settings.
Alarm
Hold in the light, start and the reset button for a few seconds a screen will appear
press the mode button it will move over the date and clock etc then you just press the reset button and start button to choose the date and time. Use the light button to set the screen.
Posted on Feb 02, 2009
SOURCE: bench seat won't collapse...how can I manually release the bench?
there is a cable; like a black cloth..here's a link you can go to; it's running late and I have to go;hope this explains it. it works for me<p>
justanswer.com/questions/1z032-99-tahoe-split-bench-backseat.<p>
good luck.
Posted on Sep 01, 2009
SOURCE: WE BOUGHT USED A LITTLE
You should be able to get what you need from the link below.
I've done a search for things with slides and had a look through but without knowing exactley what it looks like I figured you're best looking for yourself.
http://www.littletikes.com/consumerservice/toy_assembly.aspx
Posted on May 08, 2011
SOURCE: I'm looking for a Victorian looking storage bench
I'm not sure there are any Victorian storagebenches. All the Victorian benches I'm familiar with have no storage box. Maybeyou can try this, but I'm not sure it's enough storage room: http://www.overstock.com/Home-Garden/Victoria-Small-Storage-Bench/2119898/product.html
Posted on May 29, 2012
Feb 01, 2015 | Wildon Home Corvallis Trimline Futon Frame...
Apr 17, 2014 | Linon Home Decor Products Darlington...
Mar 14, 2014 | Linon Home Decor Products Darlington...
I have found you the assembly instruction manual online from
their website.
Aug 08, 2012 | Furniture
May 29, 2012 | Furniture
May 29, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Sep 16, 2009 | Mastercraft Garden
Feb 21, 2021 | Furniture
145 people viewed this question
