Question about Pitney Bowes Office Equipment & Supplies
Pitney bowes 6001 model copier giving error code c0600
Posted by Zeeshan Tahir on
5 Related Answers
Bubbabear64
Tim Babcock
  • 2794 Answers
SOURCE: Pitney Bowes Copier - C180 - Error E3
Sorry it took so long. Your copier probably is similar to a Toshiba E series. The error code is paper jammed in the bypass section.
Use this link as a lookup to the error codes
Use 4501 under Toshiba to find the error codes.
Posted on Sep 02, 2008
Everett Lin
  • 990 Answers
SOURCE: error code E 6
E6 have so many sub codes, but there indicated is duplex unit problem.
Posted on Dec 16, 2008
Adorjani Laszlo
  • 1316 Answers
SOURCE: pitney bowes model c400 copier error 0070??
Sincerely,I don`t know this model,but the error codes is similary to the Agfa,Minolta,Konica copiers.This code is the toner agitator motor malfunction code.The developer station is blocated under minimal level of toner ratio.In this case forced toner supply.Opem amd close the front door to reset.
Posted on Aug 22, 2009
hamzaskilltd
amir hamza
  • 318 Answers
SOURCE: error code e-10 on pitney bowes c360 copier
main motor rotation error
Posted on Jun 06, 2010
ynogami21
Marlon Deza
  • 670 Answers
SOURCE: I have a Pitney Bowes (Panasonic) DL355 copier
hi there,
the error code means The paper lift motors for tray 3 & 4 are not working correctly, usually caused by broken gear in lift unit.
You can check for something as simple as paper jammed between the back of the paper cassette and lift assy. Although the gear tends to get twisted when ledger paper is present(and commonly in the bottom cassette).
make sure that the pins in the harness are connected all the way? I would also try reseeding the connectors just to be safe.
1) DZLF000484 (COUPLER GEAR)
2) FFPHQ0063 (COUPLER)
3) FFPFJ00441 (STOPPER RING - in case this was lost when te coupler broke)
4) DZKM000043 (LIFT PLATE - unless you can bend it back to it's original state.)
otherwise you may have a bad system console board.
according to a thread i went to the odds of both motors going bad at the same time are very slim.
hope this helps!
Posted on Jun 02, 2011
I have a pitney bowes copier model C350 giving me an error code C0072. What is this?
Sub Hopper Toner motor mechanism malfunction.Remove rear cover,pull out toner cartridge,Remove sub hopper unit fixed under main hopper toner assembly and change the sub hopper motor or the agitator levers gears.
Aug 11, 2012 | Office Equipment & Supplies
Pitney bowes c 180 copier red wrench error
The red wrench is a maintenance indicator. Your Pitney Bowes C180 is made by Panasonic and is a model FP7718. I was going to type up the maintenance reset procedure but I will just give you a link to a page that has step by step instructions. Here it is:
http://www.copytechnet.com/forums/panasonic/6754-panasonic-fp-7718-maint-counter-reset.html
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 31, 2010 | Pitney Bowes C180 Copier
I am trying to find a fuser asm for a Pitney Bowes C550
Your Pitney Bowes C550 is made by Minolta, Model EP5000. Precisionroller.com is a good source for parts. Just do your searching by the Minolta EP5000 model and you find anything you need.
Jun 05, 2010 | Office Equipment & Supplies
Pitney bowse every time show this messages
We need your model number.
Also check your toner cartridge carefully. A toner that is not fully locked in can cause this error.
Oct 30, 2009 | Pitney Bowes Office Equipment & Supplies
Pitney bowes fax machine model 1630 has 76 error code, what does it mean
The heater lamp in the fuser is broken. Call 1 800 243 5556 for service.
Oct 19, 2009 | Pitney Bowes Office Equipment & Supplies
Pitney bowes model c400 copier error 0070??
Aug 19, 2009 | Pitney Bowes Office Equipment & Supplies
Pitney Bowes Model 9016 Error code E3 01
E3-01 is the toner bottle rotation. for some reason it is not rotating. Take out the toner bottle and be sure it is in coreectly, that the labels are not loose and preventing it from turning.
Jan 19, 2009 | Pitney Bowes C180 Copier
FAULT CODE P0500
Fuser error code. unbend a paper clip and push in hole on right side of control panel. watch the control panel on the left side about 2/3 up a dot will appear. when it shows up, press 3. press trouble reset. Touch exit.
turn machine on and off. If it comes back up, reset again. 3rd time it needs a new fusing unit. Call 18002435556 for service.
Jan 05, 2009 | Pitney Bowes C180 Copier
Error code E 6
Dec 11, 2008 | Office Equipment & Supplies
Aug 26, 2008 | Pitney Bowes C180 Copier
27 people viewed this question
Top Pitney Bowes Office Equipment & Supplies Experts
Marvin
Marvin
john h
Tom Chichester
Are you a Pitney Bowes Office Equipment and Supply Expert? Answer questions, earn points and help others
