Question about Xerox Phaser 8400 Laser Printer
Very blurry Print
Xerrox Phaser 8400 Very very blurry print. Looks like hundreds of dots instead of a printed word.
Posted by kkalkbrenner on
Tareq Bin Mostaq Mostaq
    President:
  • Xerox Master
  • 1,449 Answers
Please change your printer cartridge and buy a new one
Posted on Aug 13, 2009
Can you please tell me how to print double sided? Thanks
Xerox Phaser 8400 does not support double sided prints. You have to have a Duplex Unit for Phaser 8400 part number 097S03177 to be able to print double sided. If you have the duplex unit, on the Print dialog box just click Preferences and under 2-Sided Printing select 2-Sided Print then Apply.
Nov 16, 2010 | Xerox Phaser 8400 Laser Printer
Xerox Phaser 8400
That is a problem with print head movement. Either side to side or tilt. There is a stainless steel print head block located on the left side of the frame, about 2/3 of the way back and near the bottom, It may be contaminated with ink. Or the print head wiper may be tacked to the print head. If you want info how ot access and repair, let me know.
Jun 04, 2009 | Xerox Phaser 8400 Laser Printer
What is error code 07,010.43:32309
The print head is not moving freely.
There is s print head block that may be filled up with runoff ink, or the print head wiper blade may be tacked to the print head.
Apr 16, 2009 | Xerox Phaser 8400 Laser Printer
Blurry Printing
Quite possibly, your Wave Amp board has failed. If so, it is more cost effective to purchase a new printer than to repair yours unless you can find used parts.
Currently, Xerox is offering a trade-up rebate on new solid ink printers.
Mar 26, 2009 | Xerox Phaser 8550DT Thermal Printer
Xerox phaser 8400 error
That is a print head tilt error. Either the print head pivot block is contaminated with ink or the wiper blade is tacked to the print head.
Let me know if you want to try to resolve it yourself, I will send you directions.
Feb 17, 2009 | Xerox Phaser 8550DX Laser Printer
Phaser 8400 Printing Blurry
The Drum Encoder is behind the fan assembly.
When you take the encoder cover off be extremely careful.
Use a cotton swab on the disc only with just a light amount of alcohol on the encoder disc.
Dec 17, 2008 | Xerox Phaser 8400 Laser Printer
Phaser 8400 print management
Yes you can. If it is just you printing you can go into printing preference. Then TekColor and click the black and white option. It will force everything printed to be B&W. You can only limit others to B&W if it is hooked up via ethernet with a IP address. Type in the IP address in your internet explorer as you would a webpage. Go to the properties tab then Printing Security Settings and type in a Color Permission pin. Then if you need to give someone access to printing color in the printers preferences on the layout tab click the advanced button, Under printer features there is a color access area that you can type in the pin to print color. If one color runs out it will not continue to print. It can cause very expensive damage to your printer if it trys to print with no ink in the printhead. So to be safe it stops the machine from printing.
Hope this helps.
Nov 21, 2008 | Xerox Phaser 8400 Laser Printer
Phaser 8400 error code
That is related to the print head heating. Normally one of the print head heaters fails which requires replacement of the print head. The other item I have seen fail and cause that code is the electronics module. Both are very expensive.
Oct 09, 2008 | Xerox Phaser 8400 Laser Printer
Xerox Phaser 8400 Laser Printer Logo
184 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
