Question about Vulcan Heating & Cooling
Vulcan Quaser gas wall furnace fan keeps cutting out after 10-15 minutes of heating
Posted by myles devlin on
5 Related Answers
Anonymous
SOURCE: need fan for vulcan gas wall heater serial no. 1003129019
found a supplier using the Google search engine. Thanks any way.
Posted on May 15, 2009
Dan Favata
  • 233 Answers
SOURCE: Hi my vulcan gas wall heater goes 'bang' after a
it sounds like delayed ignition, this is VERY dangerous, you need to verify sequence of operation and fuel air mixture.
Posted on Jul 13, 2009
reyjoshua07
Reynaldo Labaguis Jr.
  • 1157 Answers
SOURCE: fan for vulcan 22 series
Hi joseph_dorri,
Vulcan has backup, if you ever do need a spare part for your Vulcan, it's good to know they are readily available across the country and can be serviced by most plumbers or electricians.
For contact details please click this link.
If you live in Melb, you may also try Tradelink (for the spare parts) or Thermal Products (for any electrical temperature controls etc). Both are in Thomastown.
Hope it helps.
Thank you for using FixYa.
Posted on Apr 20, 2011
Anonymous
  • 27 Answers
SOURCE: after i turn my vulcan
clean your jets
Muzahura Frank
  • 2069 Answers
SOURCE: Hi I have Vulcan
When on, Is the pilot strong and blue flame? If its yellow the flame is being pulled away from the T/couple or Pilot generator it will cause the unit to shut down.If the pilot light is strong it could be the T/couple or pilot generator.
It could also be the high limit switch kicking the pilot off but that's usually the case.
you should have atech look at the problem as there are other reasons that could effect its operation
Posted on May 12, 2011
My old vulcan inbuilt gas furnace now has to be run at max fan and gas to get it to heat - can you suggest what might be the problem and how to fix?? Thanks JH
Does it have good air flow? Air Filter not clogged, fan spins full speed? Lack of air flow, volume, can trip on overheating firebox.
Jul 15, 2018 | Vulcan Heating & Cooling
Furnace starts and ignites and fan comes on but when thermostat is turned off the gas shuts off and flame off but furnace continues to run. whu?? any suggestions?
The fan normally runs for a few minutes or so after the gas shuts off.
This removes the heat from the furnace and transfers it into the living space instead of just letting it possibly cause overheating of the furnace until it dissipates. If it is a fan that blows outside, that fan also needs to run for a few minutes to clear exhaust gasses from the furnace - to keep them from dissipating into your home.
Sep 28, 2015 | Heating & Cooling
Trying to locate replacement parts for my gas wall heater
http://www.enviro-friendly.com/bonaire-gas-wall-furnaces.shtml
Bonaire pyrox is the old Vulcan company
Standard Appliance Parts Sacramento California can get you anything you need as well.
Apr 05, 2015 | Vulcan Heating & Cooling
I have a dayton hanging furnace that after a few minutes the fan stops and burner keeps burning then a few minutes later the fan starts again and keeps repeating this cycle. model 3E845. thanks.
On the side of the heat exchanger is a fan Klixon that turns that motor on when the temp exceed 110f on the side of the heater. maybe that thang is going out or your fan motor needs oiling and is cutting out on overload. Next to the fan klixon is usually a limit. Both look the same. The fan klixon will have a marking stamped into the metal such as F-120 the limit will have L-240.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 28, 2010 | Dayton Gas Furnace Heater
Pyrox Vulcan gas wall furnace.
my pyrox wall furnace has a digital pad it turns off & on but i cant turn the heat or fan uo or down its 4 weeks old
Jun 13, 2009 | Heating & Cooling
Williams wall furnace no longer adequately heats home
A couple thoughts. On some of the wall furnace gas valves there's a knob that you can set for low fire or high fire. If your valve has this make sure it is in the high fire setting. Is the wall furnace controlled by a wall thermostat or a knob on the heater? With the thermostat turned all the way up like to 90, does the burner and fan continue to run or is the burner short cycling. Is the fan clean and running up to speed. Some of the Williams wall furnace had a two speed fan motor so when the fan came on at first it would run on low speed. As the heat exchanger got hotter the internal fan switch would switch it to high speed. Outside of that you would need a monometer to check the manifold gas pressure.
Aug 31, 2017 | Heating & Cooling
Heating & Cooling Logo
Top Vulcan Heating & Cooling Experts
Paul Carew
Vernon Taylor
john h
Are you a Vulcan Heating and Cooling Expert? Answer questions, earn points and help others
