Question about Tools & Hardware - Others
I have an old dunlap wood lathe. Do you know how to change the belt?
Posted by Frank Johnston on
5 Related Answers
al_kupchella
Al Kupchella
  • 843 Answers
SOURCE: how can one use a
You need a phase converter. The link below is a a selection from Grizzly. You can also find them on e-bay. There are two types - static (no moving parts) and rotary (much more expensive). The rotary type give you full performance delivering true 3-phase power to your machine. But for a minor loss in power (maybe 20%) the static type does the job quite well - assuming you don't need all of the power that your 3-phase motor can deliver. Here's the link: http://www.grizzly.com/products/category.aspx?key=275030
good luck. Vote if you found this helpful. Al K
Posted on Sep 09, 2010
drallim
  • 4088 Answers
SOURCE: Hi: I need to
Go to: www.searspartsdirect.com and enter the complete model number minus the decimal point. This will bring up a series of drawings that show every replaceable part. The manual should be listed as well. Good luck!
Posted on Jan 07, 2011
HansPP
Hans Pearson
  • 2510 Answers
SOURCE: I have aClarke CWL6 500mm/20inch
Belts are measured on their outside (wide) circumference. Place the belt adjustment in the middle of its travel and measure the length around the outsides of the two pulleys with a tape measure. This will give you a good idea of the length, accept a belt a little shorter if need be. You also need the width of the belt, this is the width across the pulley groove. Take a piece of the old belt with you to the belt dealer for him to match the belt cross section. (An automotive belt will probably be the wrong section).
Posted on Feb 02, 2011
jyackle5
Jyackle5
  • 8197 Answers
SOURCE: Where ca I get parts
Sorry mastercraft tools are made by Canadian Tire. You can not get parts for the item They will not sell parts or supply them. We get a lot of requests for parts and have called Canadian Tire and they will not tell us where to get parts. You can try to call them at (1-866-746-7287) or here is the mastercraft tool direct line. 314-429-3333
Posted on Mar 30, 2011
bentpin
SOURCE: I need a manual for
I have the lathe and got a manual emailed to me from the jet people since it doesn't show on their web page. I just called them off the contact us link.
Posted on Sep 17, 2011
Have a Craftsman 12-inch wood lathe--want to know how much to sell it for???
Should buy old Craftsman lathe
You also might see what others would be selling it for in either eBay or a trading post type of local community papers.
Sep 08, 2017 | Craftsman Tools & Hardware - Others
I'm looking for a owners manual for a ML618 wood lathe. I'm looking to see if it has more than one Chuck?
Most wood lathes, like most metalworking lathes, have a spindle that is threaded to accept a variety of fairly standard accessories including chucks and faceplates of various sizes and types to accommodate different types of work.
Any lathe that does not accept a variety of such accessories would be a complete waste of time.
Obtaining a manual for much imported machinery is almost impossible to obtain but most imported machines are close copies of industry standard machines and so generic information such as can be obtained from almost any supplier or experienced user is all that is required.
Oct 19, 2015 | Tools & Hardware - Others
I have a Ryobi ml618 wood lathe and need to know if they sell different chucks for it like a bowl Chuck
Ryobi Lathe Parts‎
www.wow.com/Ryobi+Lathe+Parts‎
Search for Ryobi Lathe Parts
Look Up Quick Results Now!
Oct 19, 2015 | Ryobi Drills
Where are the gears ?
I see no gears in the manual You can move the belt over to get a different speed if that is what you are asking.
http://content.wmhtoolgroup.com/assets/manuals/1352001_man_EN.pdf
Nov 28, 2013 | Powermatic 1352001 3520B 20x35" Wood...
Motor stopped while turning. It does have power but will not run.
Motor should have red push botton on back or bottom of motor. This is reset over load breaker . Should be out, just push in until it clicks.
Feb 15, 2013 | Powermatic 1352001 3520B 20x35" Wood...
My wood lathe is making noise
Thats a good thing, means you making chips. lol. What kind of noise exactly?
Oct 09, 2012 | Powermatic 1352001 3520B 20x35" Wood...
Fox mini lathe not running right
Could you be a bit more specific? This is a very simple machine...it either works or it doesn't. Have you checked the belt? Is it binding, or cross-threaded on the drive spindles?
Jun 16, 2012 | Shop Fox W1752 Mini Wood Lathe
I have aClarke CWL6 500mm/20inch motorised wood turning lathe.I am trying to find a driving belt for this model. The original belt has disintigrated and I don't know the size I need or where I can purchase...
Feb 02, 2011 | Garden
Looking for info/ manual for a wool lathe
look under cwl12d clarke wood lathe manual. this has all the instructions that are almost the same as the nwl37-2 i have a nwl37-2 and this manual shows what should be there.
Jan 22, 2009 | Powermatic 1352001 3520B 20x35" Wood...
Tools & Hardware - Others Logo
134 people viewed this question
Top Tools & Hardware - Others Experts
Marvin
Marvin
john h
Andrew Taylor
Andrew Taylor
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
