RCA HD52W59 HDTV Projection Television Logo
Anonymous Posted on Aug 13, 2009
Tv looks like it is in 3D
I have an RCA 52in. Model #HD52W67, i was watching a movie and the screen looked like it was squeezed and the colors looked as if the TV was in 3D, I called numerous repair shop and the cost of repair would be from $280-$400, I tried to fix the convergence in the Menu option, but it was no longer an option. Is there any way for me to fix it by replacing a fuse or something...please help. Thanks
Farmeradg
Level 1:
  • Contributor 32 Answers
  • Posted on Aug 13, 2009
Farmeradg
Contributor
Level 1:
Answers
32
Questions
0
Helped
7006
Points
50
Sounds like your convergence amp board has gone out and will need replaced. If you feel like giving it a try yourself this web site has them fairly cheap and they have an 800 line if you need help determining your board number.
http://www.moduslinkptstvboards.com/Default.aspx
My RCS HD52W67 is showing three pictures on the screen. I have tried zooming, but it only makes all three pictures larger. I cannot get it to only show one screen. What can I do?
Your TV most likely has a convergence failure. You can get parts and instructions from www.tvrepairkits.com Here are some of the most common symptoms and example photos of a convergence problem Screen looks 3D Colors don't line up One or more colors can't be adjusted when using the convergence menu. Screen is bowed or warped.
I turned My tv on and the top of the screen has red, green, and blue swirl lines, and the rest of it looks like watching a 3D movie without glasses, and the picture looks as if you took out the screen and...
The tv have a problems known as a convergence pictures problems,it is dead.Tv have any colors lines R,G,B mis alignments,have colors shadows pictures or pictures look like 3D?Yes,than the tv convergence board it is dead.The tv convergence board must have it components parts replaced like 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-$350 for parts and labors.
Hooked up PS3 to system and when watching DVD's the right side of the picture is blurry and appears doubled, like an old 3D movie without the red and blue glasses. When watching TV everything looks fine.
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
1helpful
It is like looking at 3d in all three colors. i
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
  • Screen looks 3D
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
1helpful
I have a rca hd52w67 projection tv and the screen looks like it is concaved,has three lines across the top and looks like it is in 3d. What is wrong with it?
The convergnce amplifiers have failed.
This is a common old-age problem.
This requires replacing the convergence amplifiers and possibly resistors and fuses. A repair shop would charge $300-$400 to repair.
If you are tech savy or know someone who is, thae parts will cost around $40.00. Search this site for specific instructions.
Good Day,
-Dan
4helpful
RCA P52755BA 52 inch tv looks 3D
You have a problem with convergence and all you may need to do is replace a fuse. Look up convergence for your tv model and hopefully you will get an answer as to where the fuse is located and how to replace it. Very common for RCA tv's
3helpful
RCA model R61WH76 Chasis itc222 has 3 color curved band lines on
Your model doesnt have convergence ICs. You can get the replacement parts and free instructions on how to do the repair at the following link, just click on the contact us link on the lower left hand side of the website and tell them the model number and chassis they respond quickly.
http://servicemanuals.vstore.ca/
Rca 52in rear projection hdtv red, blue, and green lines n double
tHIS is a convergence problem.. first question if you go into the customer setup menu. is the convergence option listed? If you have not got that option i suggest you read "the fl231 problem in the tips and trick section of this website. this can be a simple inexpensive repair..if you do have the convergence option then it can be one of three diffrent boards convergence power, convergence amp or small signal board. and will need further trouble shooting
My TV looks like if i was watghing a 3D Movie.
Projection TV sets have several common problems listed below.
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
1helpful
RCA HD52W67 convergence menu missing from menu and has a b,r,g line going through the top of the menu and it looks like every thing is in 3d
that model doesnt use the two STK ICs that most other models use. Try replaceing fusw fl231 . The schematics arent easially available for any RCA TVs unless they are the older projection ones. I would recommend checking with this link and seeing if they have the service manual or perhaps they can get it, if you leave an email with your model number.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
