Boston Acoustics Duo-i Horizon Clock Radio Logo
Posted on Aug 13, 2009
Unit looses time
I have a problem where my Boston Acoustics duo radio looses time overnight. I cannot believe that I could have this problem with a clock radio in this day of technology.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 16, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
808
Points
I just received a email from BA re this issue. They were amazingly prompt and friendly. Here is what I was advised to do:
"One thing to try is to let the radio recalibrate itself, this is done by leaving the unit completely unpowered and unplugged for 48 hours to let the cap drain and the unit will recalibrate itself"
How do you fix a boston Horizon Duo - I as the unit just turns on and makes a load humming sound and then th edisplay switches off
If you are lucky, it only went in protection mode and after disconnecting the power for a little while and reconnecting things could come back. But if the system did not have an overload protection, a fuse can be blown, or worse the power supply or power amp can be blown to pieces. There is one thing semiconductors don't like is work over their limit.
Why will my volume will not go past 10 on my boston duo i plus radio?
To perform a "soft reset"(all settings are erased)
Unplug radio
Hold alarm 1 button and plug in radio
Keep holding alarm 1 button until 3 numbers appear.
Release alarm 1 button and unplug radio.
Plug radio in and all will operate normally
Display Panel Light is Out
Bull, the cap is leaking all over the board and has damaged the control microprocessor. Good luck fixing that yourself. No parts available, sorry.
Power button won't turn radio off
I've got the same problem. All other functionality is fine, however I can't turn the unit off once I've turned it on. I can use the power button to adjust volume, just not turn it off, so I have to unplug it to get it to turn off.
9helpful
Boston acountic horizon duo, how do I open it, It was connected to a 240 V and after that it stopped working. I thinking of opening it and fixing the power supply component.
hi i'm looking for that solution too but found by myself you just need to remove the 2 front speaker grille just pull off and after remove the eight rubber that retained the grille the screws is under these rubbers and after gently pry the front cabinet
4helpful
My remote control stopped operating my Boston Acoustics Horizon Duo-1. I know it is not the remote because I have a 2nd Duo-i Horizon that can be operated by both remote control units. Thanks, Booker
You can contact the BA. As they will make arrangement to take it back and replace it. BA is a good company and they give consumer feedback as soon as possible. Well, only if you haven't got an answer to your question.
85helpful
3answers
All over sudden my boston horizon doesnt allowe increase the vol.
To fix: turn on unit, turn volume all the way down to 00, push and hold volume button for 10 seconds until beep then release, then turn volume all the way up to 50 (max) and push and release volume button.
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
john h
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
