Question about Timex Watches
Star Trek NG Chronoscanner. How can I set? - Timex Watches
Posted by HEDDA BANKS on
Pro trek 3500 compass only going up 300 degrees. Doesn't reach 360 north???
THe PRO-TREK watch compass is very sensitive to nearby Iron (eg. cars, fridges, steamships, artillary canons, battering rams, guillotines, etc) and anything wearable or embedded in your body. I had to calibrate mine in the middle of a baseball field.
Aug 09, 2017 | Casio Digital Compass Twin Sensor Sport...
How to set time on Casio 550 pro trek. I can't get it to set for daylight savings time.
According to Casio, in the time keeping mode hold the E until each of the following steps occur. hold SET appears in digital display>HT flashes. Second hand points to the current home city code. Set 2: Use A to select the city code you want to select as your home city. Each press of A moves the second hand clockwise. keep pressing A until it lands on the city code you need. Select your home city code before changing any other setting. Step 3: Press D to cycle through the available settings on the digital display. When the time keeping setting you want to change is displayed, you A ad or C to change it. Step 5: Press E to exit the screen, the hands of the watch will move to the time you set. Any other information or diagram is listed on the website Casiowatchparts.com
Mar 13, 2016 | Casio Watches
How do I set the alarm on a men's Casio Pro Trek digital atomic watch pq635?
Get in touch with Casio support: http://www.casio.com/support
May 08, 2015 | Casio Watches
Casio PRO TREK error 'OP EN' Display frozen with the above msg. None of the buttons - except the light - works. Whats wrong .. battery charge shows FULL
The problems is very simple: On the back cover (inside) is a little Cu metal Part. This part is glued to back cover using a poor glue (rubbered glue) and, in time, is moving from original position. You must put back this parts to original positin ( a little hole inside of back cover) and glue using a good glue. When the back cover is mounted , this part must have a ferm contact with two springs from mechanism (sensor for back cover open). If beatwin this springs isn't a electric short (using Cu metal parts) the internal mechanism of watch "see" the back cover is open and show "OPEN" on screen!
Mar 22, 2010 | Casio Watches
Casio pro-trek PRG-60T Buttons no longer activate anything.
Send it into repairs and they will send you an estimate on what it would cost to fix it. Give them a call at 800-706-2534 option 2.
Feb 19, 2008 | Casio Triple Sensor Pathfinder PRG60-1AV...
Watches Logo
Top Timex Watches Experts
Ross Keen
Pieter Vleeshouwers
Pieter Vleeshouwers
Vernon Taylor
Are you a Timex Watch Expert? Answer questions, earn points and help others
