Philips Magnavox DVD/VCR Dual Player Logo
Posted on Aug 12, 2009
Won't play dvd's
I get a disk error message when I try to play a dvd. Recorder shows the animated dvd icon in the upper right corner of tv screen, makes a bunch of noises, then about 30 seconds later the error message comes on and tells me to eject the dvd...that "playback option" might not be available. I know the dvd is not the problem as I can play it in my laptop.
Anonymous
Level 1:
Problem Solver:
  • Contributor 3 Answers
  • Posted on Aug 12, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
Questions
Helped
1081
Points
9
Try buying a Laser Lens Cleaner Disc from Wal-Mart, FYE music store, or any other place that might sell DVD players. Your Laser Lens that reads the DVD'S is full of dust. Try using the laser lens cleaner disc i mentioned to clean the laser lens.
3answers
Well the power audio system bx1121 work on smart tv
  1. Launch the Netflix app on your mobile device.
  2. Once you're signed in, select the Cast icon in the upper or lower right corner of the screen.
  3. Select the device you would like to watch your TV show or movie on.
  4. Select a TV show or movie to watch and press Play.
https://www.filehippo-free.co/
tip
Having trouble recording TV broadcast to DVD?
My LG DVD recorder was unreliable when recording TV broadcasts to "standard" DVD disks. Frequently it would begin recording a show and then stop with a copyright error message during some commercial. I rarely got a complete show. Very frustrating!
Solution: Buy some DVD-RAM disks and this machine will become totally reliable. They are hard to find and a little more expensive than +RW or -RW. Because of the copyright programming on this machine only DVD-RAM disks will work in VR (Video Recorder) mode.
2answers
Sony RDR-GX315 DVD Recorder. Error message: "The disk can be neither played nor recorded"
Which blank media do you have?
Check out CDFREAKS.com forum
Does your burner prefer + or- disks?
Try a slower burn speed
Try a different blank media.
Don't buy the cheapest disks
I have good results with Verbatum, Taiyo Yunden (Fuji)
1helpful
Disk rotating and a message "invalid disk"
you can try manually cleaning the laser lens ( gently wipe , do not press down hard , it is suspended by fine wires ) using a q-tip and a drop of that cleaning solution you got with the laser lens disc. ( fluff another q-tip a little ) then dry wipe it with another q-tip and try a disc.
you can look at the laser lens and see if you see the laser come on also to determine if that is working ( do not look directly into the laser ! )
if the laser works but it still does not read discs after cleaning it manually , then there is a problem with the focus coil on the laser or the signal board is bad
I work for Coby technical support. Our customer service phone number is 1-800-727-3592.
If the unit is showing "invalid disk" on every disk that you try to play, unfortunately, the unit has developed a defect and needs to be replaced. Our warranty is 90 days from the date of purchase. If you've had the player longer than 90 days, I regret to inform you it is out of warranty.
If you feel this solution doesn't deserve a good rating, please let me know why so that I may better assist you. If there is anything more I can do to help, I will!
7helpful
2answers
All region code for Medion DVD recorder MD84100
Found on another board, tried and it worked on my Medion
P70002 / MD84100 DVD recorder:
Turn on DVD recorder
Press HOME on remote
Go to SETUP in Easy Menu
Move down to padlock icon
Press 0 seven times
Message appears:
Congratulations!
Region Change Free!
YES (press ENTER)
It now plays US and UK as well as Australian (in my case).
1helpful
Disk unkown error message
If other dvds play then try getting the same movie but from another supplier if it persists the check yo dvd if it uses a dvd ROM then replace it with anew one.
thanks
2answers
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
2answers
My dvd always shows "system error" and won't play commercial copyright dvds, only recorded ones.
I had the same problem with my recorder except that it wouldnt play any discs at all.. I finally unplugged the recorder and left it unplugged for 16 hours. Now it is fine. I am not getting any error messages.
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
