Question about Sony Cyber-Shot DSC-S75 Digital Camera
Memory card error for sony dsc-s75 camera will not accept memory card
Posted by oeaarts on
Ty Price
    Brigadier General:
  • 11,967 Answers
Format the card in the camera. Download any pictures still on the care first using a cardreader if necessary.
Posted on Aug 12, 2009
Sony DSC-S75 Cyber-shot Cameras USB Driver for Connection Driver for vista
You don't need a driver.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Sep 14, 2012 | Sony Cyber-Shot DSC-S75 Digital Camera
I have a Sony DSC-S75 camera and I am having a problem finding a memory stick are any of the SDHC cards compatible/
The only memory card you can use are the Sony Memory Sticks. You cannot use a Sony Memory Stick Pro, so you have to find one that is under 512MB capacity and does NOT say "Pro" on it. You cannot use any other format memory card such as SD or SDHC.
Thomas
Sep 07, 2011 | Sony Cyber-Shot DSC-S75 Digital Camera
I have Sony DSC H7 camera and when i insert my Scan Disk 4GB memory card it gives me error as "Re-insert memory stck", please advice
Your Sony camera is designed to use only memory stick PRO DUO with maximum memory 8 GB. It will not accept other memory cards. If you have been use memory stick pro duo and still request you to re-insert card. Remove your card and re-insert firmly. Regards
Dec 13, 2010 | Sony Cyber-shot DSC-H7 Digital Camera
I need a member card for 3.3 mega pixels digital camera where can i buy one from?
You can get memory card from amazon.
Click the link below to direct you to the direct link for buying the memory .
Memory card
Hope this helps.
Jan 30, 2010 | Sony Cyber-Shot DSC-S75 Digital Camera
My Sony DSC-S75 camera shows a format error when I insert my 128MB memory stick also blinking is C:13:01. Any idea's how to fix? Thanks!
Format error display shows memory card is unstable and need to be format through format option in Camera menu.
Format memory card, if that does not fix the issue, try another memory card in camera and check this memory card in another camera just to make sure either camera got problem or memory card is bad.
Jan 01, 2010 | Sony Cyber-Shot DSC-S75 Digital Camera
Will DSC-T1 accept a MARK 2 memory stick?
NO, DSC-T1 will not accept such big memory card as its hardware supports maximum 2GB card memory that is more then enough for it because its 6 mega pixel camera.
Jun 26, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
I have a Sony Cyber-shot 2.0 mega pixels digital camera, and needed to get a larger capacity memory stick (I had 8MB and 16MB only), so I went to Best Buy and the guy there sold me a Sony Memory Stick PRO...
The Sony DSC-S75 will only accept a maximum 128MB memory Stick. I know it accepts the original sticks am still waiting to see if it will accept the PRO sticks.
Apr 23, 2009 | Cameras
Memory Stick problem with Sony DSC-P2 Digital Camera.
Hey stevekschan,
You should be able to use any kind of Memory Stick you want. BestBuy.com has many sizes of memory sticks available.
Sincerely,
Allan
Go Ahead. Use Us.
May 07, 2008 | Sony Cyber-Shot DSC-P2 Digital Camera
Dsc-s75 capacity
The 85 and 717 were the first cams able to use a contigous 256Mb Pro stick as far as I know, the 707 and 75 are stuck with the originals or the Switchable ones which defeat the object as if you've gotta pull it to switch "halves" you may as well take 2 normal and cheaper sticks along..
Sep 11, 2005 | Sony Cyber-Shot DSC-S75 Digital Camera
Sony Cyber-Shot DSC-S75 Digital Camera Logo
Top Sony Cameras Experts
Vish Iyer
Vish Iyer
gbob59
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Sony Camera Expert? Answer questions, earn points and help others
