How to reload digital settings - Audio Players & Recorders
Posted by Phil on
What is the default password for cisco
There are two main methods to return a Cisco router to its original factory defaults. These two methods are described below.
Method 1
1. uses the config-register 0x2102 command in global configuration mode.
2. Check the configuration register on the router by issuing the show version command.
3. The configuration register setting is displayed in the last line of the show version command output and should be set to 0x2102. If this is not the case, enter the config-register 0x2102 command once in global configuration mode.
router#configure terminal
router(config)#config-register 0x2102
router(config)#end
router#
4. If the show version command is issued again, the same line in the command output will have '(will be 0x2102 at next reload)' appended to the current register setting.
5. Erase the current start-up configuration on the router with the write erase command.
Reload the router with the reload command. When prompted to save the configuration, DO NOT save.
router#reload
System configuration has been modified. Save? [yes/no]: n
Proceed with reload? [confirm]
Once the router reloads, the System Configuration Dialog appears.
--- System Configuration Dialog ---
Would you like to enter the initial configuration dialog? [yes/no]:
The router is now reset to the original factory defaults.
Method 2
1. uses the config-register 0x2142 command in global configuration mode.
2. Enter the config-register 0x2142 command in global configuration mode.
router(config)#config-register 0x2142
This causes the router to ignore the start-up configuration on the next reload. If a show version is issued, the last line in the command output will have '(will be 0x2142 at next reload)' appended to the current configuration register setting.
3. Reload the router using the reload command in enable mode. It is not necessary to save when prompted to save the system configuration.
router#reload
After the router has reloaded, the System Configuration Dialog appears.
4. Enter no to the question "Would you like to enter initial configuration dialog?"
5. Change the configuration register setting to 0x2102 by entering the config-register 0x2102 command once in global configuration mode.
6. Issue the write memory command in enable mode to overwrite the existing start-up configuration with the current running configuration.
7. Reload the router with the reload command in enable mode.
Once the router reloads, the System configuration Dialog appears.
Note: The configurations below are stored in ROMMON, and cannot be reset to Factory Default Settings by the write erase or config-register 0x2142 commands.
warm-reboot
memory-size iomem <not default>
Jun 18, 2013 | Computers & Internet
How to load the prepaid card worth of 300 to my smart buddy sim?
Hi
How do I quickly reload my Smart Buddy account? Those constantly on the move can avail of easy reload through:
a.) Call and Text Card
b.) Electronic PIN Voucher
c.) Mobile Banking
d.) SMART Money
The Call and Text cards and Electronic PIN vouchers are available in P300 and P500 denominations. They can be purchased from any SMART dealer, agent, and other accredited distribution outlets such as selected gasoline stations, supermarket and convenience stores nationwide.
REMEMBER!
Do not not accept tampered, unsealed or re-sealed Call and Text Cards or those whose 14-digit PINS have been revealed.
To Reload your Account Using a Call and Text Card or Electronic PIN Voucher
1. If your are using a SMART Buddy Call and Text Card, lightly scratch off the protective link on the card to reveal the 14-digit PIN. If you are using an Electronic PIN Voucher, tear off the covered voucher through the perforation at the sides to reveal the 14-digit PIN.
2. Dial 1510 14-digit PIN SEND
A voice prompt will confirm if your reload attempt is successful.
You will be given 5 attempts to successfully reload your account. After 5 invalid attempts, you will be barred from further reload attempts for the day. Reloading may be done the next day starting 12:00 am.
It is highly recommend loading additional Call and Text card value into your account to ensure smooth and continuous service. There is no limit to the amount or value you can load in your account.
Thanks for using Fixya.
Apr 15, 2011 | Computers & Internet
Speakers not working
Use the sound card software and set the output to DIGITAL only
Sep 16, 2009 | Boston Acoustics BA735 Computer Speakers
I have changed computers resently and can't find the soft ware to reload and I need to charge my daughter's hannah montana mix max. Where can I get to software to reload.
Go to the website of what you need to reload and if they have a search tab type in "Driver" or "Install files" They might have them available for download. Then just run the .exe file.
Sep 11, 2009 | Disney Mix Max Digital Media Player
SECURITY PASSWORD VOLUME SETTINGS
the only way to reset the locks on any ipod is to do a restore
hook up to itunes and restore, then reload your music
May 20, 2009 | Apple iPod nano
RCA TV with Guide Plus that no longer receives guide at night
Please clarify what you are getting. Is the Guide Plus coming up with no programs listed? If so, it may be that you lost power and the set has to be turned off overnight to "reload" the program schedule. If that is not the problem, have you recently changed to digital through a digital receiver? You need to have your analog antenna connected to receive the program listings. You may have to install a splitter to have both the digital antenna and the analog antenna connected. I have an RCA with Guide Plus and ran into the same problem, but solved it by reconnecting my analog antenna and leaving the set off overnight to reload.
Feb 15, 2009 | Televison & Video
Canon 350D over expose
this needs workshop attention, metering check. Check the manual there may be an adjustment.
May 14, 2007 | Canon Digital Rebel XT / EOS 350D Digital...
Some Songs Play Too Slow
This sounds like it may be realted to the "Time Scaling" feature, which is part of the "EAX" settings. Disable EAX and/or the Time Scaling feature and see if this helps.
Oct 02, 2006 | Creative Labs Nomad Jukebox Zen Xtra MP3...
18 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
