Car Audio & Video Logo
Posted on Aug 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Delco radio - Model # 16194965 and need a connection harness and color coded shematic showing how to attach power and speakers. Where would one get this information? Thanks
Joel Friedenberg
Level 3:
  • Master 1,114 Answers
  • Posted on Aug 12, 2009
Joel Friedenberg
Master
Level 3:
Answers
1114
Questions
0
Helped
440682
Points
3272
The following link shows the GM Radio color code. I hope this helps!
http://www.installdr.com/Harnesses/GM-Wiring.pdf
2004 Buick Rendezvous CX. Where can I find the car radio wiring diagram for it please?
You buy a harness from the the aftermarket radio shop that supplies you with the new radio.
RADIO - Buick Rendezvous CXL 2004
Automotive Electricians Portal https://portal-diagnostov.com > 2020/04/04 > radio-bu...
Apr 4, 2020 - RADIO - Buick Rendezvous CXL 2004 - SYSTEM WIRING DIAGRAMS Base Radio Wiring Diagram, with Rear Controls. Get Access all wiring diagrams car.
2004 Buick Rendezvous Radio Wiring Guide
MODIFIEDLIFE https://www.modifiedlife.com > 2004-buick-rendezvo...
Our 2004 Buick Rendezvous radio wiring diagram shows you all the 2004 Buick Rendezvous radio wire colors and what they do. Use our 2004 Buick Rendezvous stereo ...
Buick (2004-2006) Century, Regal, Rendezvous Head Unit ...
PinoutGuide.com https://pinoutguide.com > ... > Buick pinouts
Jan 28, 2022 - OEM radio stereo harness pin assignment. Hardware connector pinouts and cables circuits ...
BUICK RENDEZVOUS 2002-2005 VEHICLE WIRING
JustAnswer https://f01.justanswer.com > BUICK+RENDEZ... PDF WIRING INFORMATION: 2002 Buick Rendezvous. WIRE. WIRE COLOR. WIRE LOCATION. 12V CONSTANT. ORANGE. Ignition Harness. STARTER. YELLOW. Ignition Harness.
5 pages
4helpful
I need to know the color codes for a Delco #09383045 for a 2000 chevy S-10
The radio number has nothing to do with the wiring. Here is what the book shows.
2000 Chevrolet S10 Pickup Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Dark Green
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Violet/White
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Need color wire coding for delco model 16176761 in 95 camaro. casette deck quit so I bougt after market radio but can't interpret color of wires attached to original radio - which color is hot, which...
Try going to (not calling) your local PARTS DEPARTMENT at your local dealer,. they should be able to print you a copy to go..
Best regards
Ck
Please provide feedback ratings
2helpful
I have an delco electronics radio for my GMC 1500 Sierra 1994. Model no is: 16179985 There is no harness so I need to know what goes where! Many thanks Anders Australia
Is this a stock GMC radio you are putting in your Sierra, if so, visit the scosche or PAC website to see if they have one available. If you are installing an aftermarket radio, then you need to purchase a wiring harness. It will have the color coding on the package. If you don't have the vehicle side of the harness, again, visit the scosche or PAC website for availability. Hope this helps.
I want to change my F-150 radio, basic, with a radio/cassette/cd, will I need a different harness?
You will need a harness adapter for your model truck. This you will want to solder and heat shrink over the solder joints (Dont just twist tem together) then just plug it in to the factory harness.
You will probably need an adapter kit also.
The wiring harness adapter should come with the color codes for the wires corresponding to your trucks speaker and power wires pinouts make sure you correctly connect them to the color codes of the stereo for proper speaker placement and voltages
1986 NISSAN 300Z THE STEREO WIRE WERE CUT NEED COLOR CODE PLEASE TRYING TO INSTALLED A FTER MARKET STEREO JVC
i have attached the wiring info you requested. be sure to test all wires with a meter before connecting. also a link to metra's website if you need an installation kit
http://www.metraonline.com/fitl.aspx
Battery RED/BLACK (+) RADIO HARNESS Accesory BLUE (+) RADIO HARNESS Ground N/A THIS RADIO GROUNDS THROUGH THE CHASSIS MOUNTING BRACKETS. Illumination RED/YELLOW (+) RADIO HARNESS Dimmer N/A Power Antenna GREEN/BLACK (+) RADIO HARNESS LF Speaker (+) BLUE/WHITE LF Speaker (-) BLUE/YELLOW RF Speaker (+) BROWN RF Speaker (-) BROWN/WHITE LR Speaker (+) RED LR Speaker (-) GREEN RR Speaker (+) BLUE RR Speaker (-) PINK
I am trying to put a delco radio in a 93 ford thunderbird but the harness is striped to just wires i need the color coding on them so it will work
the red usually is the power input, black is the ground.
attach a ground wire to a 1.5v battery and tap the + of the battery to any of the stripper, when you hear the tap sound from the speaker,that will tell you what wire to which speaker.
if you have any wire left over, try for power ant.
Radio codes
Battery WHITE/YELLOW (+) RADIO HARNESS
Accesory WHITE/RED (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
Illumination RED/BLACK (+) RADIO HARNESS
Dimmer RED (-) RADIO HARNESS
Power Antenna YELLOW/WHITE (+) RADIO HARNESS
Amp Turn On YELLOW/WHITE (+) RADIO HARNESS
LF Speaker (+) WHITE
LF Speaker (-) ORANGE
RF Speaker (+) YELLOW
LR Speaker (+) RED
RR Speaker (+) BLUE
RR Speaker (-) BLACK
1helpful
I need radio color codes for a 2001 fordranger
The simplest way to figure out wire colors on the ford is to purchase the radio wiring harness from a stereo shop like a Metra or Scosche harness and match the aftermarket wiring color code to the opposite side (vehicle side) of the radio plug. If you are just replacing speakers, then removing the speaker from the car with the plug attached, you can easily figure out polarity. Just connect a 9v battery to the speaker leads on the speaker (NOT THE CAR) for a second will make the cone either pop out or **** in. When the cone pops out, note the polarity of the + on the 9v battery. This is the positive for the speakers. Hope this helped.
Top Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
