Clean the coil behind the fridge or under the fridge (where ever they are) and make sure both fans are running, the one in the freezer and the one underneath. If that don't work you may be low on freon replace fan motor
Your unit isn't defrosting. Your fan blade is hitting the frost that is built up in the back of your unit. All Samsung units are made when you open the door that the fan stops. You can check this but finding your door switch and see if the sound still continues. But you will need service and a part to fix this unit. Where are you located? We are the master tech company for Samsung in the Charlotte, NC area.
The fan is hitting on ice buildup...
Check out these tips...they can help you figure out what
is going wrong withyour refrigerator
and why it is not cooling
Refrigerator
not Cooling or Fridge not Cooling
How to Defrost
Refrigerator Defrost
Timer Problem
Water
Running in refrigerator from Freezer
Refrigerator
or Freezer not Cooling or Getting Cold
heatman101
