Question about Onkyo TX-8211 Receiver
Onkyo TX8211 I think I had a power surge in my house about 6 months ago. The following week, the receiver would go into protect mode in intervals if I had it turned up only a tenth of the way, then it would just not turn on at all. After I got around to replacing the a/c fuse, the stand by light would come on but if I click the power button, the fuse is immediately blown and nothing happens. I'm hoping it's not the transformer or fused circuits. May be the power supply board?
  • Anonymous Aug 17, 2009
    not bad! i was expecting much worse news. thanks a lot!
ABRsvcs
  • 4,234 Answers
The most likely problem is shorted output transistors. This is a straightfoward repair for any shop that works on audio gear. Expect a parts cost in the $40-$50 range.
Dan
Posted on Aug 13, 2009
Testimonial: "ok. i was expecting much worse news! thanks a lot for your help!"
Had a power surge and now my Onkyo TX-SR607 will not power on. Only get a constant click sound. Any repair advice?
although power surge can trigger activations of protection circuits,
there are at times, damage is done before it is activated.
• Check first for low power supply regulators,
then check for possible output stage failure.
let me know if you need further assistance!
Sep 09, 2012 | Onkyo Tx-sr607 7.2-channel A/v Surround...
My onkyo tx8211 stay on a stand by mode. I can
If it's anything like my Onkyo surround receiver, pressing any input selection will turn on unit.
May 16, 2010 | Onkyo TX-8511 Receiver
How do I reset from the amp protect mode Onkyo receiver TX-SR600?
How do I reset my amp / receiver from protect mode ?
May 07, 2010 | Onkyo TX-SR605 Receiver
TR SR706 purchased 6 months ago. Unit powers on to
Onkyo USA Corporation
18 Park Way
Upper Saddle River, New Jersey 07458
For Dealer, Service, Order and all other Business Inquiries:
Tel: 201-785-2600
Fax: 201-785-2650
Hours:
M-F 9am-5pm ET
For Product Support Team Only:
1-800-229-1687
Hours:
M-F 9am-8pm | Sat-Sun 10am-4pm ET
Regional Service Center Dtr Technologies
2525 West 6th Aven
Denver, CO 80204
303-573-6288 (Tel)
Distance: 960.0 miles
show map
Please see below for local Service Centers.
Media Associates Inc.
612 National Ave.
Mountianview, CA 94043
650-968-2444 (Tel)
Distance: 33.6 miles
show map
http://www.onkyousa.com/loc_results.cfm
Oct 04, 2009 | Onkyo TX-SR501 Receiver
After my house was it by lightning my Onkyo
If your receiver was connected to any power source and that power source was not a surge protector strip there may be damage to the receiver as lighting travels. Another thing to consider is the fact that many people will put their equipment on surge protectors but the cable is still connected to the TV etc...This is just another avenue for the lightning to get into the home and blow up your system. I always disconnect any cable from my computer and TV. The power source from the wall is also unplugged when there is a storm just to be sure. Surge protectors are limited in their use as well. I don't believe they can take too many lightning hits. It is best to change them out.
Jul 18, 2009 | Onkyo HTR500 Receiver
Listening mode functions lost one by one
It needs service. Not worth repair though.
Jun 09, 2009 | Onkyo HTR500 Receiver
Onkyo TX SV7M Knocked out by Power Surge
Try pulling the plug out of the wall for 5 min or more,give the unit a chance to reset.Hopefully you didn't get a power surge that might have blown the protection circuits.
Jan 03, 2009 | Onkyo TX-SR705 Receiver
I have the Onkyo TX-DS656. The problem is that the power is on, but I get no sound. House was struck by lightning and had a bit of a surge. All other functions seem to work just fine. Rumor has it that the...
The unit is in protect mode because a problem was detected in the output section. In all likelyhood, the output transistors have failed or a secondary power supply hs failed. Because this was the result of a power surge, I would suggest that you take this to a sericer and request a detailed repair estimate. This could be as simple as a voltage regulator gone bad to the microprocessor being fried. This is not a problem that can be diagnosed remotely.
Dan
Jun 23, 2008 | Onkyo Audio Players & Recorders
DX-C390 turn on
Use a surge protection power strip (such as the Power Protect AV 600 by Monster Power).
This will elliminate erratic behaviour of the unit, since even minute fluctuations in the power source from unbridled house current will affect the sensitive internal components of the Onkyo DX-C390 6-Disc CD Changer.
Dec 07, 2007 | Onkyo DX-C390 6-Disc CD Changer
Stuck in protect mode
i believe protect mode is because you have the wrong impedence speakers, they are too low (4 ohm? 6 ohm?) it chols work with 8 ohm speakers
Aug 16, 2007 | Onkyo TX-SV454 Receiver
Onkyo TX-8211 Receiver Logo
606 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
