ECU is like your mother board and inside there is a PROM which is coded for your cars engine type and size etc. This prom keeps the systems as they should be like during warm up highway driving etc. Takes info from all the systems and makes fuel mixture, timing, and other adjustments to keep the car running correctly.Your prom needs replacing I think. This has to be done very carefully, Maybe best to take it to a shop.
Dear Its related to fusser temp. Check the fusser assy. thermostat it may open . either it may reset or replaced with new one. The error code mean-OPEN HEAT ERROR.
thanks
Hello,4 Digit Failure
Code
F0 - E0
Analog to
Digital Failure
Disconnect
for 30 seconds - if display re-appears - replace control
F1 - E1
Safety flip
flop
Replace Electronic
Range Control/Clock(ERC)
F2 - E0
Shorted keypad
Replace Electronic
F3 - E0
Oven temperature
sensor or oven temperature sensor fuse opened
Replace oven
temperature sensor or fuse
F3 - E1
Oven temperature
sensor shorted
Replace oven
temperature sensor
F3 - E2
Oven too hot
Replace oven
temperature sensor
F3 - E3
Clean temp
too hot
Replace oven
temperature sensor
F5 - E0 F5
- E1 and E2
Check door/latch
switch
Replace component
2 Digit Failure
Code
F0 or F1 or
F5
Failed transistor
Replace Electronic
F2 - E0
Oven temp
too high
1. Test
operation of door lock on self-clean models 2. Test relay contact operation 3. High resistance in oven temperature sensor
F3
I have the same issue - it Shows "E2" on the time Display...
I already checked the Speed sensor and inclination potentiometer and both are OK... Moreover, I found that EEPROM Memory (Microchip 93LC46) is broken (reads "00"). After replacing it, I Need a way to reset / recalibrate the treadmill. I found on some Forums that there shall be a key combination (Speed+ & Start / Stop or similar) but None works for me. Could you please (if available) post the User Manual page describing the calibration entry? Or, maybe, advice a way to calibrate the 1050? Even the EEPROM Content (I guess the it is an issue) will be really helpful. Thank you in advance,
either any of the key(button)is got stuck up prtessed or the motor of the washer is got weak.due to this e2 error code shows up.the washer works if the motor is weak but if there are more clothes in the washer and due to that motor cannot spin properly so it shows e2.First clean the washer internally after emptying it completely then check.if still e2 error then motor needs replacement .
you can get new motor at
www.repairclinic.com
E2 indicates failure or out of tolerence evaporator sensor which is foamed in and not replacable.
The only repair posibility is replacement of the electronic control board which now ignors input from the sensor
