Question about Motorola Mobility ROKR E6 Smartphone
Iphone wont turn off after reset.
I decided to reset my iphone. It gave me that it might take up to 2 hours and it did. When it finshed resetting the phone wouldn't turn on. it just shows the screen with the apple logo then shuts off. a minute or less later it does the same thing, the logo appears and it does it again.
Posted by zakout3 on
  • iman sherrif Oct 08, 2011
    i tried to press the power button and home button together but it does not work
JDTec
  • 4,338 Answers
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Aug 13, 2009
Anonymous
    New Friend:
Take out the sim card and open itunes and reboot and it should fix the problem
Posted on Jan 31, 2010
Anonymous
    New Friend:
Ok so i was going to sell my iphone so i had to reset then after reseting all the settings it took like an hour then i reset it again and just in case so then after reseting the apple logo came and the load cicle came right under the logo and after that loaded it would keep happening again so i let the battery die and still would not work so i was so pissed i had to check youtube and it wasn't there
Posted on Mar 10, 2010
How do I factory reset my phone?
IF it's a Iphone go to settings look under General scroll all the way down and you will see Reset it will ask you these types of questions.
1.reset all settings
2.Erase all content and settings
3.reset network
4.reset keybored dictionary
5. reset home screen layout
6.reset location & Privacy!! Hope i helped you any:) " GOODLUCK"
Apr 17, 2015 | Samsung Cell Phones
My iphone 5c stopped working suddenly, its screen darkened and it does not work. What is the problem?
Reset the phone:
  • Plug the charger into the phone.
  • Hold down the Home button while holding down the On/Off button.
  • Continue holding these down until (hopefully) the Apple displays on the screen.
Mar 08, 2015 | iPhone 5c Cell Phones
Iphone touch screen wont work
Hi there,there are some solutions which can fix that:
1.You can press the power button and home button together for 10 seconds.The iPhone will show up and reset.
2.Maybe the iPhone 4 LCD Screen Touch Digitizer AssemblyLCD Display Touch Screen for iPhone 4 are damaged.I know the LCD show image,but the touch screen should be changed together with LCD.So,please go to the repair shop to change your front screen.That is a complete front iPhone 4 LCD Digitizer Assembly.
Apr 01, 2013 | Apple iPhone Smartphone
Iphone reset takes long time at last 12 hours finsh
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Oct 06, 2012 | Apple iPhone 4S
My iphone went dead. I hung up from a call and then went to use it again - dead. Plugged in for 1/2 hour and still no juice. Is there a reset button?
Charge your iPhone overnight. If that does not work, try the following resets:
  1. Press and hold the Home button for at least ten seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for 10 seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  4. More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 17, 2011 | Apple iPhone Smartphone
My iphone was accidentally placed into large font. Now I cannot enter my passcode as the full key pad is out of view Help
Reset the phone by pressing the power and home key at the same time and holding them until it turns off, then restart. If that don't work you will need to restore the phone in itunes
Dec 02, 2010 | Apple iPhone Smartphone
I decided to reset my iphone. It gave me that it might take up to 2 hours and it did. When it finshed resetting the phone wouldn't turn on. it just shows the screen with the apple logo then shuts off. a...
Try doing a forced reset. Hold down the home button and the power button at the same time until the apple comes up. Hopefully it will be able to boot from there. If not, I would try to restore it again through itunes. It is possible something just went a little off.
Aug 12, 2009 | Apple iPhone 3GS Black (16 GB)
Frozen jailbroken iphone 3g
I'll recommend you re-break your phone and if you are willing to perform the task in a more simple yet time-saving manner, follow the step by step guide from this website: iphoneunlockeasily.com
Jul 24, 2009 | Apple iPhone 3G
Firmware dosen restart after reset the iphone 3g 16gb
Put it into Restore Mode by turning it off by holding the Home and Sleep/Wake Buttons at the same time until the screen goes black and then WHILE holding the Home button, insert the wire and do not let go of the Home button until iTunes finds it. Then Restore it from iTunes.
Feb 16, 2009 | Apple iPhone 3G
Motorola Mobility ROKR E6 Smartphone Logo
10,844 people viewed this question
Top Motorola Mobility Computers & Internet Experts
Tom Chichester
JessicaChane2345
Dream
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
