Well you can please follow the below steps - 1. Unplug the DVD player and take the outer casing of the DVD player off. This entails either taking out two or three screws or simply sliding one of the pieces of plastic in either direction. 2. Locate the disc loader cover. The disc loader cover is located where the extending DVD tray finally comes to rest within the DVD player. It's the part that holds the DVD loader in place. 3. Bend the two tabs outward that hold the loader in place. This is a delicate procedure because you don't want to hurt the device. The tabs are relatively easy to break since they're plastic in most cases. 4. Slide the disc tray out. If your disc got stuck before it was read, it's probably still on this tray. If so, your problem is solved. However, if the disc was fully set and loaded, the job isn't quite finished yet. 5. Move the small mechanical arm that holds the disc in place over so that the disc and the reader are both exposed. Some DVD players will not have anything holding the disc in place. Instead, these devices use a system not unlike that of a common DVD case. The DVD will be locked in place in the center. 6. Carefully lift the disc up and out of its loaded position in the DVD player. This may entail sliding the disc reading mechanism over slightly. This won't hurt the device as long as you're careful. You should be able to access and remove the disc.
Would
you like to review the features of the Cambridge Audio DV30 DVD Player?
Have
you lost your Cambridge Audio DV30 DVD Player Users Guide?
Would
you like a digital, searchable, pdf version of the Cambridge Audio DV30
DVD Player Owners Manual? Follow this link (& click FREE)
to download a pdf version of the Cambridge Audio DV30 DVD Player
documentation.
Would
Have
you lost your Cambridge Audio DV30 DVD Player Remote Codes?
Would
DVD Player Remote Codesl? Follow this link (& click FREE)
remote codes documentation.
Would
Have
Would
Would
Have
Would
documentation.
Would
Have
Would
Would you like to review the features of the Cambridge Audio DV30 DVD Player?
Have you lost your Cambridge Audio DV30 DVD Player Users Guide?
Would you like a digital, searchable, pdf version of the Cambridge Audio DV30 DVD Player Owners Manual? Follow this link (& click FREE) to download a pdf version of the Cambridge Audio DV30 DVD Player documentation.
