Question about Freezers
I want to connect to alarm relay for So-Low freezer PR120-9. Does anyone have a product manual with wiring information? Thanks!
Andrew Taylor
    Top Expert:
  • Freezers Master
  • 33,314 Answers
Mfu14f3gw2 wiring diargram
Good Morning Jon - The best way to locate a Wiring Diagram for this particular unit, MFU14F3GW2 is by visiting the manufacturer website. The Owner's Guide and Parts Manual are also available. Hope this information is helpful and if there is anything else that I can help you with, please feel free to reconnect!
Jun 09, 2013 | Frigidaire Freezers
What rewiring is needed to replace the overload relay with a universal kit, on an upright freezer? Kelvinator model VA16 W. There are two relays that connect to the compressor that need to be replaced....
The two pieces are Relay and Overload.
If you are using a supco relay/overload combination that has three wires with terminals and two wires with stripped ends the wiring is as such.
Red-Run Terminal, White-Start Terminal, Black-Common Terminal (Overload was wired to this)
Stripped wires are connected to line cord along with condenser fan wires.
Nov 19, 2010 | Frigidaire Freezers
I need to replace my thermostat on my ge chest freezer model #fcm7sudww, I lost the wiring diagram and I need help to rewire. Thanks
Wiring diagram of the chest freezer turned into chest fridge. The junction box is not required if all connections are made inside the fridge service compartment. Active (A) connection passes via latching relay terminals
inside the thermostat.
Additional information can find HERE.
Hope helps; tell us news.
Aug 05, 2010 | General Electric Chest Freezer FCM5SU
Indesit c239 freezer not getting cold red light constantly on
If you take the rear cover off the inside of the freezer you can see the evaporator coils. observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Aug 15, 2009 | Freezers
Low temp alarm goes off on Kenmore upright freezer
The alarm is there for a reason. I wouldn't disconnect it. Maybe the compressor is low on gas. If your thermostat is on extremely low, try moving it up to a less cold position. Look in your owner's manual for recommended settings.
Failing that, get ready to shell out some bucks to the service man!
Mar 19, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
The alarm keeps going off. Food is frozen fine just alarm
That alarm is there for a reason. Grab your owner's manual and see the different things it can mean. If the gas is getting low, that could be it, and you'll want to solve it as early as you can.
Sometimes a power surge or brown out can make that alarm go off. Try unplugging it for 5 minutes.
Mar 11, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
1)forget about the key you'll be disposing of this unit anyway
2)the alarm is to tell you that the unit is above ideal temp.
3)the unit isn't making temp due to refrigeration issue. if it isn't cold enough on 3 then 1 won't do it either.
Apr 09, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Freezers Logo
150 people viewed this question
Top Freezers Experts
Dennis Boxerman
Muntejaya Ginting
Muntejaya Ginting
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
