Question about Whirlpool Freezers
Water not getting to the ice maker - Whirlpool Freezers
Posted by koolcats on
christian nielsen
  • 358 Answers
Either the water valve that opens when the ice maker calls for water (located in the back of the fridge at the bottom) went bad or is leaking and the fill tube to the ice maker gets clogh with frozen water and when it calls for water won't get through, in both cases you need to replace the valve.
Posted on Aug 17, 2009
Won't pump water to tray.
How a Portable Ice Maker Works - NewAir
www.newair.com/articles/how-a-portable-ice-maker-works/
Look inside to find out how a portable ice maker works, and get some tips about ...Just fill a tray with water, stick it in the freezer, wait 30 minutes or so and, bam, ice! ...Power supply - if the unit won't turn on, make sure if it is plugged into an ... Leakingwater - If the pump is operating but no water is reaching the freeze tray, ...
Customer Reviews: Igloo Portable Countertop Ice Maker ...
https://www.walmart.com/reviews/product/15162429
WalmartIgloo Portable Countertop Ice Maker ... My wife is lazy and never refills the ice traysto put back in the freezer. ... Great ice maker for camping trips and parties. ... even though the thing is completely empty so it won't make anymore ice, and 1/3 of .... My satisfaction was quickly marred by the sheer volume of the water pump in ...
Igloo Portable Countertop Ice Maker - Walmart.com
www.walmart.com/.../Igloo-Portable-Countertop-Ice-Maker/151...
Walmart
Rating: 4 - ‎350 votes - ‎In stock
Buy Igloo Portable Countertop Ice Maker at Walmart.com. ... It features a 3.1L capacity water reservoir that can make up to 26lbs of ice in 24 hours. You need not drain the melted ice ..... A. yes, the ice tray that hold the finished made ice is right about the water reservoir. .... A. Jogie: No, it won't make crushed ice, only cubes.
EdgeStar Portable Ice Maker - Troubleshooting Help ...
blog.edgestar.com/.../edgestar-portable-ice-maker-troubleshooting-help/
Jan 31, 2016 | Igloo Cooler Igloo Portable Countertop Ice...
Jen Aire Fridge ice maker fingers are below the
This one you have to take out the ice maker and run hot water from the kitchen sink into the tray to get the ice out. need model number if you want detail explaination how to. or just use a hair dryer that will work to!!! if fingers dont rotate after defrost ice then the gears are stripped, replace ice maker
Mar 27, 2010 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
I have a side-by-side (MDL: 106.53552202). My ice maker has stopped working... I do get water from the door. The ice container is empty, the switch is turned ON.
there could be a blockage of frozen water in the fill tube of the ice maker.
if there is no blockage then the nex thig to check is the main water valve that supplies the water to the ice maker.
you can check the power from the main pcb board to the ice maker and make sure you have current to the ice maker
if all else fails replace the ice maker
i hope this has helped in some way good luck
Jan 31, 2010 | Freezers
No water to ice maker but I get from the water dispenser
Check the waterline as well as the valve supplying water to the ice maker.
Sep 27, 2009 | Freezers
Ice maker not making ice
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips and replace it if it does.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Sep 03, 2009 | Freezers
The fridge is no longer making ice
OR
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Aug 19, 2009 | Freezers
Water lines to ice maker are clear and pressure is good but the ice maker recieves no water to make ice
Take a 6 inch piece of 14 gauge insulated wire and strip one inch of insulation off both ends of the wire. Bend the wire into a U shape. Remove the plastic cover from the front of the ice maker.Locate the holes marked L and V. Insert the 2 stripped ends of wire into the L and V slots. If you get water,the ice maker is bad. If you do not get water,the water valve is bad.
Aug 18, 2009 | Kenmore Freezers
ICE MAKER NOT MAKING ICE, WATER NOT FEEDING INTO ICE MAKER
you may have a frozen inlet tube coming in to the ice maker. This is caused from a bad water valve and you would need to replace the water valve.
Apr 02, 2009 | Frigidaire Freezers
Kenmore Ice Maker
Sounds like a water valve problem to me. Force the ice maker to cycle. (turn it off and let it get cold for at least an hour then turn it back on). Test for voltage on the ice maker side of the valve. The valve is usually in the back near the floor. Just follow the water line. Another solution. switch the wires on the water valve. then try the water dispenser and see if it makes the ice maker fill up. See if when the ice maker cycles water comes out the door. If the ice maker causes water in the door , replace the valve, If door switch causes ice maker to fill up replace ice maker again.
Jun 27, 2008 | Freezers
Freezers Logo
96 people viewed this question
Top Whirlpool Freezers Experts
Muntejaya Ginting
Muntejaya Ginting
Dennis Boxerman
Lawrence Oravetz
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
