Question about Midland Radio Communications
Midland two way radio 7Q-0351C What size fuse is require on the 12 VDC power lead?
Posted by Skip Apple on
Jim
    New Friend:
  • 28 Answers
I think you meant 70-0351c?
I believe this is a 60 watt transceiver. So if you remember ohms law P=IxE or power equals amps times volts so 5 amps times 12 volts equals 60 watts. Use a 5 amp fuse.
Posted on Aug 29, 2019
5 Related Answers
Anonymous
SOURCE: Refrigerator totally inop. 120 VAC & 12 VDC present. Unit is model # RM3662.
Yes, I did the same thing. I had a qualified RV repairman change out the board. He also told me there is a recall on this specific issue and that DOMETIC should pay for not only the board, but quite possibly the cost of the labor to repair.
Dometic phone # is 888-803-0013
Posted on May 29, 2009
bob_computer
Project NOMAD
  • 3153 Answers
SOURCE: Pin Name Color Description
Yes this is a good list of the voltages to be expected from a newer power supply on just the main header
Posted on Aug 11, 2009
Anonymous
  • 18 Answers
SOURCE: http://pinouts.ru/Power/atx_v2_pinout.shtml
um what you want lol:?
Posted on Sep 07, 2009
Libran Moreno
  • 126 Answers
SOURCE: I have a Clarion xmd3 radio that will not power
check to see if you have any grounding issues or if ground is present
Posted on Jun 12, 2010
billfox1966
bill fox
  • 231 Answers
SOURCE: What power supply required ? 12 VDC ?
5V 2AMP
Posted on Dec 23, 2010
My Vertex Standard VX-2200 display blinks continuously and when i press the ptt button it say error
Not enough power. The radio requires a steady 12 VDC input, or in a vehicle, 13.2 VDC. You did not mention if this is a 25 or 50 watt radio. I guess 50 watt. This occurs often when the wire is too thin for the amperage required. Get thick wire or the harness may not provide enough amps and it will get really, really hot! The wiring harness from Vertex is the best one. If you have checked all your wiring AND the power connections, it is less likely a programming error. Let us know!
Jul 12, 2017 | Vertex Radio Communications
Ok so i have a Pioneer DEH-P5200HD it started shorting out when i replaced my ignition . Now it wont power on . If i run a new power wire by connecting red an yellow wires "ignition an 12v to battery...
Sounds like something was shorted out while replacing your ignition or you damaged a ground wire. You can try connecting just the 12+vdc switched lead to 12+vdc power and then ground the receiver to a chassis ground somewhere else to see if it is just a grounding issue. The yellow lead (memory) will also need to be connected in higher end units such as Alpine as the audio amp pulls from the memory lead rather than switched lead.
Nov 11, 2013 | Car Audio & Video
Can i connect a Uniden UH089NB UHF 2way radio to 12 & 24v
Hi John,
Page 5 of the manual for this radio specifies a 13.8 VDC (12VDC car / truck electrical system) power supply to power the radio.
Connecting to a 24 VDC system will damage the radio and likely require expensive repair or replacement.
Feb 01, 2012 | Uniden Radio Communications
Driving lights dont come on
provied u check the baulbs n thyre good theres a drl relay in the fuse box under the hood
Sep 20, 2011 | 1999 Pontiac Grand Am GT
How do you check the battery status?
Check battery voltage using Volt meter=> it should be about 12.6 to 13.8 vdc.
Pull the battery out... checking the deforming at the case ..such as "swelling"... if yes .. replace the battery.
Replacement battery is about 10-20 dollars on e-bay (watch for shipping charge and size. and terminal connection sizes )
The average life of battery on UPS is about 5-7-10 years wi)th UPS plugged in (Charging
One I had my local Autozone checked my 12 VDC -8 AH ... ask them to set CCA at about 100 AMP...
for 12 VDC -14 AH ask them to set CCA about 200 AMP.
For a 12 VDC -75 AH (group 24) they set the load on their tester at about 700-900 CCA.
You can also buy a manual battery load test at Harror freigt tool for about $20 US dollars (On sale)
Feb 18, 2011 | APC Back-UPS ES 350 - UPS ( external ) -...
Ran fine on the way home turned off the engine...went back a couple of hours later to go to the store and now it will not start...electrical is fine, glowplugs warm and everything but will ot turn...
Actually there is a power lead on the starter solenoid that goes from the ignition to the starter solenoid. When the key is turned to start that lead (+) should have 12 VDC to ground. If there is 12 VDC power to that lead when the key is turned to start then the starter solenoid is bad.
If there is no 12 VDC then is could very well be part of the remote start / alarm system that is not allowing 12 VDC to the solenoid.
You can verify the starter is good by using and external jumper wire to the terminal from the ignition on the start solenmoid. If the starter engages then by all means look into remote start / alarm related solutions.
Thanks for using FixYa!
Kelly
Feb 14, 2010 | 2005 Ford F 350 Super Duty
CB hook up to car battery for home use
Yes you can do it..
even use wind-mill to make power to charge battery(s)
Serial and parallel battery configurations
http://batteryuniversity.com/partone-24.htm
Jul 02, 2009 | Midland 1001Z 40-Channels Base CB Radio
Apr 01, 2009 | HP Compaq dc7100 PC Desktop
Radio Communications Logo
119 people viewed this question
Top Midland Radio Communications Experts
eradiostore
eradiostore
lars ahlsen
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
