Question about SanDisk Sansa m240 MP3 Player
I need a driver for my sandisk sansa m240. i have windows vista.
Posted by panadepeste on
Lee A.
  • 4,472 Answers
That model is not fully compatible with vista. So either it works or it doesn't. if not go back to using it on an xp machine.
Thanks,
lee
Posted on Aug 12, 2009
Vinay Tevatia
    President:
  • 1,884 Answers
5 Related Answers
mixmaster
Timothy D
  • 626 Answers
SOURCE: How to download the software of SanDisk Sansa m240 MP3
You dont need any specific drivers. As long as you have Windows XP / SP2 and Windows Media Player 10 or higher. The drivers are part of these required components. Best of Luck.
Posted on Sep 06, 2007
Anonymous
did you try the website, usually they have the software
Posted on Jul 27, 2008
Anonymous
  • 948 Answers
SOURCE: i want driver for sansa sandisk m240 for windows xp proffessional
No driver is needed, Windows XP has native support for this device if you are current with your Windows updates. I have used three different players this exact model. All you must do is connect the device to your PC with a USB cable and it shows up in My Computer.
If you are not current with your updates, go to http://www.windowsupdate.com/
Posted on Jan 10, 2009
  • 102366 Answers
SOURCE: need driver for sandisk sansa m240 mp3 player
You can download the driver from the manufacturer's web site at http://www.sansa.com
Posted on Mar 09, 2010
muntejaya
Muntejaya Ginting
  • 10422 Answers
SOURCE: sandisk sansa m240 mp3 player sftware for laptop ibm thinkpad
Hi, please download it here :
www.sandisk.com/sandisk-support/driver-download-wizard
www.computing.net > Forums > Drivers
Regards, Jay
Posted on Feb 18, 2011
Mi Sandisk m240 no la leen los pc
La compania Sansa tiene respuestas a varios problemas en espanol en este link: http://kb-es.sandisk.com/app/answers/list/search/1/kw/sansa%20m240%20manual , Quizas se encuentra alli una respuesta.
Paara pensar en soluciones a su problema hace falta mas informacion: el tipo de pc que esta utilizando (mac o windows, si windows, cual systema - windows xp, vista o windows 7?). El aparato m240 se enciende y reproduce la musica que ya tiene?
Hay dos modos de conectarse el m240 a un pc: MTP (Media Transfer Protocol) para sincronizarse a traves de un servicio como i-tunes, y MSC (Mass Storage Class), que actua como un usb Flash Drive en la compu. Posiblemente su m240 esta en modo MTP y si lo cambia a MSC se reconoce por el pc (vea http://kb.sandisk.com/app/answers/detail/a_id/207/kw/m240 en ingles).
Quizas si pregunta de nuevo en ingles recibira mas respuestas que le ayuden: My Sandisk m240 is not recognized by my pc, or does not appear in My Computer when connected to my pc.
Jul 04, 2011 | SanDisk Sansa m240 MP3 Player
I can not instal my mp3 sansa m 240 in windows vista i need to view like an external masive storage from copy the files
do you have the disk of your sansa m 240? if yes then install the drivers first, then try transferring the files. if no then contact the shop from where you purchased your sansa m 240.
Dec 08, 2009 | SanDisk Sansa m240 MP3 Player
Sansa m240 not being recognized, even after changing to msc
try this it is a driver for that specific MP3 player also if that download don't work search of Sansa M240 driver and other sites should be available for that driver to download
http://www.drivers.mrjuan.com/driver-5953-sansa-m240.html
Just select your operating system of course its XP download should start up hope this is helpful!!
Jul 26, 2009 | SanDisk Sansa m240 MP3 Player
Device driver m240
Uninstall all Sansa software using the add/remove programs function. Reinstall software from Sansa CD. Then and only then plug the mp3 player into the computer.
Nov 04, 2008 | SanDisk Sansa m240 MP3 Player
I WONT ADRIVER
Drivers are not necessary. You need Windows XP / SP2 and Windows Media Player 10 or higher. They supply all the necessary drivers. Best of Luck.
Oct 07, 2007 | SanDisk Sansa m240 MP3 Player
MY PLAYER HAS MUSIC LOADED THAT IS NOT VIEWABLE BY THIS TECHNIQUE BUT THAT IS ANOTHER PROBLEM THAT I CANT FIGURE OUT YET
Sep 05, 2007 | SanDisk Sansa m240 MP3 Player
Adding music.
open up windows media player and select copy to disk or device then drag you r songs to the right side of the screen and then on the left select the bar and find sandisk sansa m240 and then click the copy button
Aug 02, 2007 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa m240 MP3 Player Logo
536 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Jean Sintulaire
Muntejaya Ginting
Muntejaya Ginting
Daniel Dollive
Daniel Dollive
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
