Question about Hitachi 60V710 60" Rear Projection HDTV
Hitachi 60v710 yellow tint to screen with normal in center to top
Has a yellow tint on white background all except a couple inches in the center when a blue water scene is on the center is blue but the sides are green
i did a screen wipe but after 4 hours of running it no change
Posted by beowulfricha on
Anonymous
    Sergeant:
  • 273 Answers
Sounds like a magnetic field near your screen
Posted on Aug 12, 2009
The whites are yellow and theres a yellow tint to the picture in general although not real bad. Is this just the lamp # ux21513 needing to be replaced? Thank You
The Lamp would cause the picture to be dimmer but not discolored. I would suspect the Optical Engine is causing the yellowish tint. Due to the cost of replacing, call Hitachi at
1800-448-2244 and see if they would be willing to help with the repair.
Hope this helps,
Skyassoc
Jul 18, 2009 | Hitachi 60V710 60" Rear Projection HDTV
Red circle and yellow tint in our white
If you have RED color that starts from Center of the Screen,(no red color on sides ) 100 % your light engine is deffective..
In order to solve this issue Replace Light Engine Control Board (also called Driver Board ) attached to light engine.
Good Luck
Do not forget to Rate!!
Dals123
Jan 03, 2009 | Hitachi 60V500 60" Rear Projection...
Panasonic PT-50LC14 LCD rear projection
well it gets real compicated, if you are good with electronics and can take apart and put back together the inside the projector needs cleaned or the easy fix replace light engine about $600.00 rebuilt
Oct 07, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Yellow tint
your unit has gotten dirty.The lcd pannels need cleaned
Mar 01, 2007 | Hitachi 60V710 60" Rear Projection HDTV
Yelowing in screen
I contacted Hitachi about this problem and they were very cooperative with me. They agreed to replace the light engine. When I mentioned that I had done some reseach on the internet and saw that they repaced the light engine and covered the cost of labor for some other customers, they said that they would submit a request for the labor for the repair. As it turned out Hitachi covered the part and labor for the repair. I first contacted Hitachi in March 2009, By mid May the service-center recieved the part and performed the repair.
Yellow tinted halo
you need to have the lcd pannels cleaned
Feb 26, 2007 | Hitachi 60V710 60" Rear Projection HDTV
Color problems at top and bottom of screen
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.eserviceinfo.com/
http://www.digitalhome.ca/forum/search.php
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 17, 2006 | Hitachi 42V715 Rear Projection Television
Hitachi 60V710 60" Rear Projection HDTV Logo
Top Hitachi Televison & Video Experts
Paul Bade
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
