Question about Wharfedale PowerCube PC-10 Subwoofer
Wharfdale sw150 subwoofer ticks then pops
Its been getting quite frustrating considering i've spent quite a bit of money on my sound system and it has been doing it for awhile now. it pops sometimes quite frequently and when i turn the sub off it sometimes makes a massive POP. would love too hear any feedback you guyes can offer me .
Posted by lloyd2004 on
Dayton Computer
    Master:
  • 669 Answers
Is the + - correct? Are the Ohms matching? Cables and attachments ok? Output wattage: matching? Could also be related to a Shielding problem. The subwoofer power board may be defective, poor contacts, condenser variable resistor is defective, and so may other issues too numerous to mention here. What ever the case, the problem seems to be isolated to the subwoofer itself.
Posted on Feb 07, 2018
L. Sawyer
    Habit-Forming:
    Scholar:
  • 158 Answers
It should go into standby mode when you shut the rest of your system down. The led on the back is supposed to be green when in use and red when on standby. I believe yours should have the "auto on" switch on the back. If you are manually shutting the sub off make sure it is the 1st thing you power down. It should not pop then. As much volume as it puts out you could damage the speaker if you do anything to cause a pop. If it pops while watching a movie or with music, check connections. I believe the manual says left input is the recommended one.
2 Related Answers
Anonymous
  • 14 Answers
SOURCE: Wharfdale PC 10 subwoofer
Some basic trouble shooting is required here. First you need to see if it is a problem from your source or the sub. Try a different source to the sub-woofer and see if it changes the response. If still nothing on the sub, then most likely there is an issue with the amp or driver. Check to see if there is a fuse on the sub, if so, it could be blown. There could also be an issue with the auto switching circuit on the subs amp, in that case, it would need to be repaired in the shop. But before that I would check all of the connections to the sub, and also to the driver in the cabinet. If everything looks good, then put some type of source directly to the woofer to see if it works, if you get sound, then looks like the amp has a problem. Again a repair or replace issue.
john
Posted on Aug 20, 2008
Anonymous
SOURCE: Wharfdale moviestar 70 speekers and sub
i have the same moviestars 70+ plus a yamaha rx-v750 put the crossover on the sub to maximum (left knob) volume (right knob) about 2/3 clockwise. change the crossover on the yamaha to anywhere from 80-120 ( the 120 will put more bass to the sub) if your yamaha has sub level/volume control set it higher, also if it has LFE/sub out set it to sub only.
Posted on Mar 11, 2009
Wharfedale sw150 amplifier circuit diagram
the wharfdale SW150 is a subwoofer (hence the SW for Sub Woofer) , not an amp
try again
Feb 25, 2015 | Audio Players & Recorders
Manual to connect sw8 sub
The SW8 and SW150 have line level and speaker level inputs. It has a line level output, which will not drive speakers without using a separate amp for the signals.
Jan 20, 2015 | Wharfedale SW150 Subwoofer
Hi i" ve bought on
This may help. If it's not the exact model you have it will at least get you started as subwoofers are pretty much teh same for connection and operation.
http://www.wharfedale.co.uk/Portals/0/PDF_Data/Manual/DIAMOND9_range.pdf
Others here...
http://www.wharfedale.co.uk/Support/Download/Manuals/tabid/71/Default.aspx
May 06, 2011 | Wharfedale SW150 Subwoofer
It lights up but does not produce any sound,thamks
Possible that the fuse has blown or the power amplifier is defective. you will need to remove to check even to check the sub woofer coil for continuity - if the coil has opened up or is damaged.
Mar 08, 2011 | Wharfedale SW150 Subwoofer
Can I connect my floorstanders to wharfedale sw150 without any external amplifier, If so, how ?
What 'floorstanders'?
Its internal amp is for its own subwoofer ONLY, but if you use your own amp's full-range speaker-level outputs to feed two chanels entering the sub you can tag the 'floorstanders' onto the sub's speaker terminals as speaker wire extenders. Your amp will be powering the floor units.
I'd keep the sub separate and feed it LFE only if it was mine.
Feb 02, 2011 | Wharfedale SW150 Subwoofer
Yamaha YST-SW150 Subwoofer
hi, is it a humming noise ??? check if the connector is plugged in properly,check the earthing, if its a three pin mains plug, if its a two pin, then the CPU SMPShave a proper eathing. let me know
Jan 10, 2008 | Yamaha YST-SW150 Speaker
Sub doesnt sound loud
try to change subs with your friend to find out if the problem is on amplifier or on sub wofer
Nov 21, 2007 | Q-Logic QLT-.3508SS Car Subwoofer
Wharfedale PowerCube PC-10 Subwoofer Logo
130 people viewed this question
Top Wharfedale Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Wharfedale Audio Player and Recorder Expert? Answer questions, earn points and help others
