Question about Dell Inspiron E1505, Intel Core 2 Duo T5300 , 15.4-in LCD, 1GB RAM, 120GB SATA HDD, 256MB
The montitor goes black and/or the system shuts down after only minutes of use. a detailed test of the system did not reveal any problems.
Posted by rdg5980 on
Anonymous
    Scholar:
  • 100 Answers
Dear rdg5980,
Try to replace the battery (if it is a Laptop PC) or try to check the hinge or rainbow-cable that connect your Power to Monitor screen, it might be the socket little bit loosen.
GoodLuck!
Posted on Aug 28, 2009
After driving 20-30 minutes I shut the truck off and it will start but then dies and wont start again for 40- to a hour
I have a similar problem. My engine shuts down after about five minutes..
Measuring the current into the distributor(ignition) reveals a jump in current from 3 to 40 amps.
The power lead is red on white and the ignition lead is yellow on black and goes into a connector under the dash where the ignition wire changes to white on black. Three different wiring diagrams give no clue to how this problem is caused.
Also, the starter is good for only a few turns after the engine warms up.
Mar 20, 2013 | 1986 Mazda B-Series
Vs248 hdmi doesnt work
Also sometimes the hdmi cable goes bad I had 2 of them go bad.
Aug 18, 2012 | ASUS 24" Widescreen LED Monitor VS248H-P...
I have a dell latitude laptop my problem is, it takes over 5 minutes to power off. I click shut down screen goes to desktop screen no icons about 5 minutes later it says its shutting down screen goes black...
There may be nothing running in task manager that you can see but there is still something running,My advice is to take it to your local Geek Squad or preferred computer tech you most likely have a virus that is slowing down your computer process.
Sep 24, 2010 | Dell Latitude D531 Laptop Computer PC...
Blank Screen
Common problem in monitors are bad caps in the power supply, that is the first place to check, look for bad caps with bulging top/bottom, see example of failed VIEWSONIC monitors due to bad caps here (worst case will be bad lamps): http://s807.photobucket.com/home/budm/allalbums
Post back what you see so we can help you further.
Feb 06, 2010 | ViewSonic VG2230WM LCD Monitor
Viewsonic VG2230wm 22 Blank screen
Look for bad caps in the power supply first, see example of failed VIEWSONIC monitors due to bad caps here: http://s807.photobucket.com/home/budm/allalbums
Post back what you see so we can guide you furhter.
Feb 06, 2010 | Relisys RLT1720 17" LCD Monitor
Monitor shuts down ,turn off turn on montitor comes back on for a few minutes then goes off again
your power supply needs repair. you need to remove the rear cover. look at the power supply for leaky/crowned capacitors and replace them.
Dec 26, 2009 | Acer Computers & Internet
Monitor goes black after running for a few minutes. Brand new 22 inch sceen.I prees the button to turn it on and it says Analog and goes black again. I have to shut down the computor to get it to come back...
Sounds like the computer is shutting it down and the monitor is fine. Check for viruses then check your settings in device manager for the screen saver and power down (screen off) options.
Aug 10, 2009 | Dell Computers & Internet
JVC HD DILA 56G886. replaced lamp and now it shuts down after 10
we found that it is an auto shut off system on the TV due to over heating. The lamp, if not cooled correctly shuts down. We added a mini fan in the back and it seems to work fine now.
Jan 25, 2009 | JVC HD-56G886 56" Rear Projection HDTV
Black Screen
No, this is typical problem for defective inverter. Mostly screen appears for some seconds and then turn to black. If you are technician, you can use this link :-).
http://www.lcdrepair.us/1702inverter1900x.html
Oct 01, 2007 | Dell 1703FPs 17" TFT LCD Flat Panel...
Dell Inspiron E1505, Intel Core 2 Duo T5300 , 15.4-in LCD, 1GB RAM, 120GB SATA HDD, 256MB Logo
104 people viewed this question
Lee Hodgson
Lee Hodgson
Ekse
efs_perpends
efs_perpends
