How to Set the Time & Date for a MP25DV Canon Calendar & Clock Printing Calculator
The steps listed in the Calculator Instruction Manual for the Canon MP25DV Calculator did not work. The correct steps for setting the time and date on this calculator are listed below:
1. Press the time/calendar button one to select the date mode. The display should show the month-day-year. 2. Hold down the = button until the month start flashing. 3. Use the number keys to enter the current date, month and year. Example 07-22-2021 4. Press the = key to set the current date. 5. Press the CE/C key to return back to the calculator mode. 6. Press the time/calendar button twice to select the time mode. The display show the hour-minute-seconds & time of day. Example 02-01-14 A 7. Hold down the = button until the hour start flashing. 8. Use the number keys to enter the current time. 9. Press the X button for (A) a.m. or (P) for p.m. 10. Press the = key to set the current time. 11. Press the CE/C key to return back to the calculator mode. 12. To check the current date and time on your calculator, press the calendar/time button once for date and twice for time.
To set the date, make sure that you are in Rate Set. type in the date such as August 3, 2010 would be entered as 08.03.2010 then press the date time key. This will set the date. To set the time type in the time such as 4:20 PM would be entered as 16.20 then press the date time key and this will set the time.
how do i program my phone to show name and phone when someone is calling and how do i change time nad date and year i have a ativa digital answering machine
OK, I bought one over the weekend just for chuckles. I figured it out.
On the top of the calculator there is a key that shows a little clock. Punch it once and the date appears...like 01-01-2000 or somesuch. Press it again and the time shows up..
Hold the time set key (=) down for a second until the first zero starts to flash. All you have to do is start punching in the time. When you are done press the time set key again. Voila!
Punch the key with the little clock again and the date shows up. Hold down the time set key for a second like explained above until it starts flashing. Enter the date with the key pad numbers. Done!
I couldn't figure this out either till I looked above each key (didn't notice what it said). Anyway, look real close.
Hope it works out for all and everyone finds this solution...
To set the time: Press the date/time button (next to the feed button) to make the time appear on the display. Then press and hold the "Time Set" button (the "=" button) until the first digit of the time setting begins to flash. Then just enter the current time with the keypad (3:30 is 0-3-3-0) and use the "AM-PM" key (the "x" button) to toggle am/pm. After you have the time entered, press and release the "Time Set" (=) again to set the new time.
To set the correct date: Press the date/time button (next to the feed button) to make the date appear on the display rather than the time. Then press and hold the "Time Set" button (the "=" button) until the first digit of the date begins to flash. Do the same as before to set the new date. Don't forget to press the Time Set button after you set the date or it will not record the change.
If for some reason you need to reset your calculator, turn it over and stick a pencil into the reset hole next to the battery compartment. That will reset everything.
try this one have your calculator set on "on" press the "time/clock" button once, when date appears on calculator press the "M+=" and hold until first number on date flashes, enter the date you want, when done switch your calculator from "on" to "print". date should be saved.
Go to the link below. You need adobe acrobat to read. THere is a section in the manual called "Adjust Date & Time"
For Date:
Put Calculator on RATE SET
Press Time/date key: enter the date using a decimal between the month, day and year (all 4 digits) please the date/time button. It should reset. (Exmple: 01.16.2009)
For time:
Leave Calculator on RATE SET
Press Time/Date key until time shows up. just like date, press the hour then the decimal then the minute. (Example if the time is 10:15 you enter 10 . 15) Press the Time/Date Key and the time is set.
