Question about Toys
Which tenders are awarded for training in 2019?
Posted by Thabo Rammekwa on
Coupler will not stay closed on tender this was new out of the box
Contact Lionel Customer Service for a repair/replacement or take the tender to a Lionel Service station.
Jan 27, 2016 | Crafts & Hobbies
C & O tender coupler will not stay closed
IVE Sseen couplings offered 4 sale on sites such as amazon and ebay b4
Lionel 2466WX Tender -- HOW do I get it to WORK? (Assuming that it does work)?
Good work, Dan! Fixing trains can be as much fun as running them.
Apr 22, 2014 | Crafts & Hobbies
We are having difficulty turning on our New Bright Holiday Express Animated Train set. Husband and I have been trying to figure this out for our eager 2 little boys. The remote seems to turn (red light)...
Here are a couple of resources from New Bright:
http://www.newbright.com/public/electric-train-faq
http://www.newbright.com/images/Manuals/384%20ws%20manual.pdf
There is no On/Off switch on the train. Power goes from wall plug to transformer, then from transformer to track clip, which must be attached to the track. A control line goes from the track clip to the controller. Mine has a green light just above the red On/Off button that will come on even if the engine and tender are not on the track. The tender does all the work, and must be connected to the engine and on the track. There are four sliding contacts between the tender wheels that provide contact with the track.
Dec 09, 2010 | New Bright Small Holiday Express Train
How do you replace the batteries in James the train?
James the train has a tender attached to him. On top of the tender there is a black plastic piece that looks like coal. Slide the black plastic piece towards you and you will see the battery underneath it.
Sep 30, 2010 | Thomas and Friends Battery Operated Train...
I have a Newbright Musical Holiday Station Electric Animated set No. 385. Everyt car on the train lights up but we can't get the train to move or take any of the commands from the control panel. What could...
Check to make sure you have the large plug from the tender car to the loco plugged in correctly and secure. The tender car supplies power to the loco and if that cable is not connected the train will not run.
Dec 15, 2009 | New Bright 384 Holiday Express Animated...
Will not run or make sounds, control panel lights are on but no response when we push buttons.
Check some of the other solutins I have posted regarding this issue, but you can check to make sure your track is getting power by using a volt meter set to DC. You should measure 10.5VDC between the tracks.
When you set the Treetop tender on the tracks and turn on the power, the tender car should light up if you have power. When you add the loco and plug in the large black cord from the Tender to the Loco, the train should light up as well. If you are getting power you should then be able to press the forward button and the train should start.
Make sure the clips on the track control box are making contact with the rails on both sides. If your getting power to the track and the tender lights up, you should be good to roll.
Dec 12, 2009 | New Bright 384 Holiday Express Animated...
I have power to the track and the controller, but not the train.
I assume you have the Treetop Tender car on the track? The treetop tender is car that makes the electrical connection between the track and the train.
1. Use a volt meter across the track. You should have about 10.5VDC on the track (anywhere on the track)
2. Even without the Loco on the track, the Treetop Tender should light up if you have power to the track. If you have power and the tender does not light. Check the brushes located between the wheels on the tender. These are the motor brushes that pick up the current from the track for the train set. Make sure they are contacting the track.
3. Add the loco to the track and plug in the large black plug from the tender to the loco. Turn on the power and press forward. The train should start rolling.
Try all the functions, bells, ho ho ho, all aboard etc ..
Add one car at a time and make sure that each one lights up before moving on to the next.
Dec 05, 2009 | New Bright 384 Holiday Express Animated...
Train powers up,lights go go.Press forward and it just buzzes.Doesn't move. New Bright said it's the 'Tender Car ".
The tender car supplies power from the track to the entire trian.
Make sure the train will run with just the Loco and the tender. Make sure the tender is securely plugged in to the Loco and make sure the the brushes under the wheels on the tender (this is how power gets from the track to the train) are in contact with the track. Finally use a scotch brite pad (DO NOT USE STEEL WOOL) to clean up the track a little.
You can also take a volt meter and measure for DC between the rails. You should have about 10.5VDC on the track. (Inside rail is neg on mine and outside is pos) ...
Hope this helps..
Bob
Toys Logo
146 people viewed this question
Top Toys Experts
Marvin
Marvin
Tom Chichester
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
