Hi All, I have just bought a new computer and it came with a widescreen
LCD. I thought I would use my old 19" AOC LM929 monitor for my CCTV
cameras at home as the screen is too good to dump.
I have used a
Grand vision 2000 so convert the CCTV signal to SVGA? and the monitor
shows an on screen message saying "input not supported". If I turn on
the screen with my finger holding down the menu and power button the
the box says "OSD locked". This then clears and I can use the monitor
without the "input not supported" box floating round the screen.
My
problem is when the CCTV switcher changes to another camera the monitor
looses sync and I have to switch the monitor off and start up with the
menu button pressed all over again.
Is there a way I can disable the error messages permanently...possibly pressing the buttons in a certain way to achieve this?
Many thanks
Confused!!
Check your switchers resolution settings .....
You might have to change your resolution settings....
This solution is for AOC Monitors......
Setting the Optimal Resolution
The recommended resolution for this monitor is 1680 by 1050. To setup the monitor to this resolution, follow the steps below.
External Controls
Press the power button to turn the monitor on or off. The other control knobs are located at front panel of the monitor (See Figure ). By changing these settings, the picture can be adjusted to your personal preferences.
* The power cord should be connected.
* Press the power button to turn on the monitor. The power indicator will light up.
Hope this helps ,
Rate me please,
Cheers Misterdj
Figure is from the following AOC link...
http://aoc-europe.com/manuals/TFT_203Swa...
SOURCE: How do you remove the on screen display?
Sorry, seems like the cctv hardware does not like the type of monitor your using. How you tried a different display and does that correct the problem?
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
