Question about Boating
I have a Suzuki DT65, all is fine until motor warms up then i loose mid range, it's either idle or flat out, can someone help with this problem.
Posted by jonfipa on
Anonymous
    New Friend:
My Suzuki DT 65 outboard will start (fire up) but not run, after being in salt water, I have removed plugs, placed a sqirt of 2stroke oil in pots and turned engine over, drained the carbs, replaced the fuel and cleaned out the fuel filter and lines, Can you help
Posted on Sep 05, 2010
Anonymous
    New Friend:
Have a Older DT65 and the MOTOR is clean but wont tur over and sounds like a bearing in grinding or somthin
Posted on Nov 12, 2009
HAVE TO REPLACE A CDI UNIT NEED A BREAKDOWN DT65 SUZUKI 6501
Suzuki DT65 1978 Wiring Diagram Page: 1 - iboats Boating Forums ...
forums.iboats.com/...suzuki.../296297-suzuki-dt65-1978-wiring-diagram Jan 5, 2009 - 6 posts - ‎4 authors ... diagram for a Suzuki DT65 6501 D-10978 (assume this is 1978). ... I looked around for a shop service manual on the internet, located a ...
Jun 23, 2015 | Suzuki Motorcycles
1994 Samurai fuel injection. 2800rpm until warm up, then idles down
Check the operation of the coolant temp sensor.
Check the thermostat is also working properly.
May 18, 2012 | 1994 Suzuki Samurai
Well the motor locked up and i couldnt kick it at all shifted threw all the gears just fine but i wuz messing with it and i ran through all the gears trying to turn the back wheel and knock it loose didnt...
If you are running 5th gear mid throttle the compression in the motor wasnt enough to push the piston back down
for the record ( i run a ts 250 savage 2 stroke ) i,ve done it my self it happends
try to keep it the power band you will be fine
good luck.
Mar 26, 2011 | 2004 Suzuki RM-Z 250
Suzuki outboard motor 65 hp --oil sensor keeps
assuming you are not out of oil in your oil reservoir you probably have a bad sending unit in the reservoir. never bypass it or eliminate it as you could permanently damage your motor or ruin it if you ran it out of oil.
Jun 19, 2010 | Boating
99 gsxr 750 losing power after 10k rpm if you have
The carburetor jets, there are 3 bands; A low, mid range and high range rpms. 10k would fall in the Mid range power. I would let the bike warm up a little bit and tweak the middle knob on the left side of the bike and keep in mind you need the right mixture so turn it quarter turn one way at a time per testing the mid range rpms while riding, tweaking 1/4 turns in between tests. If it gets worse, turn it the other direction until you find that sweet spot in the mixture of fuel/oxygen. The carburetor jets, there are 3 bands; A low, mid range and high range rpms. 10k would fall in the Mid range power. I would let the bike warm up a little bit and tweak the middle knob on the left side of the bike and keep in mind you need the right mixture so turn it quarter turn one way at a time per testing the mid range rpms while riding, tweaking 1/4 turns in between tests. If it gets worse, turn it the other direction until you find that sweet spot in the mixture of fuel/oxygen. The carburetor jets, there are 3 bands; A low, mid range and high range rpms. 10k would fall in the Mid range power. I would let the bike warm up a little bit and tweak the middle knob on the left side of the bike and keep in mind you need the right mixture so turn it quarter turn one way at a time per testing the mid range rpms while riding, tweaking 1/4 turns in between tests. If it gets worse, turn it the other direction until you find that sweet spot in the mixture of fuel/oxygen.
Mar 07, 2010 | 2007 Suzuki GSX-R 600
Boating Logo
673 people viewed this question
Top Boating Experts
ray gallant
Andrew Taylor
Andrew Taylor
Bill Boyd
Are you a Boating Expert? Answer questions, earn points and help others
