I just finished a load of clothes and the washer seemed fine. I tried to start a second load and no matter what setting I use it flashes dl f?
Any ideas - thanks
Fdl is a code that indicates a door lock error. This error occurs because the door cannot be locked. The door will try to lock six times before displaying the error code. You have a faulty door lock switch. Hope this helped and best wishes.
I had the same problem. I took off the top of the washer moved the wires around had no luck with that. I reached all the way down to where I thought the lock should be and found the black lock and moved it up and down a few times and now it works!!! Just want to say I am not handy at all and I found this to be an extremely
easy fix.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
OVER SUDDSING
