Question about iLO MP3 Player
It wont turn on even with a new battery
It said low batery so i put a new one in it and it wont turn on. ive tried three different kinds of batteries! still nothing
Posted by damngirlies on
Anonymous
I had this problem with my ILO MP3 player - I ended up taking it apart and discovering that the power button wasn't making direct contact with the switch - made a small adjustment and it's been working ever since - hope this helps
Posted on Sep 03, 2009
Cant take more than 2 pictures because it says the batteries are too low, while new batteries are in. What can i do?
Just a hunch - your camera's in-built capacitor is malfunctioning. You need to send your camera to service.
Aug 30, 2014 | GE A1250-BK 12MP Digital Camera with 5X...
My device batery ran low and turned off and wont turn back on what do I do
Try a new battery if you have one available.
-If you don't, and have friend with same phone or similar, check to see if the batteries are the same
-Try a different charger. (sometimes your charger head becomes loose and useless)
-Wiggle Cable - see if creates light to come on or off.
-If under year warrenty - call cell provider, usually will replace your phone under manufactor's one year warrenty - ex. easier to deal with getting a replacement from Verizon rather than straight thru Motorola
Apr 08, 2011 | HTC EVO 4G Smartphone
My Canon PowerShot SX10 IS WILL NOT turn on , ive tried everything , and ive even gone on youtube to look for videos to fix it , i cant find any . ive had the camera for 3 years
HI..
The possibilities to consider for this kind of problem are quite a number
the bateries you are using might be defective, so you can get a new set of bateries with the voltage and wattage or charge the old one appropriately..
the contact for the battery could be the problem if there is rust in it. this would need cleaning..
the power switch of the camera might also be faulty, this would require you to take the camera to a repairer.. if you got warranty on it you can consider using it or look for a good engineer around you to fix it..
i hope this information will help you
Feb 04, 2011 | Canon PowerShot SX10 IS Digital Camera
I have an m5310 and i have troubles with the battery charge i bought a new battery but is still the same , i plug the notebook to the ac power and batery start to load (the front green light is on ) after...
Try to perform power drain on the motherboard.
heres the steps:
take out the battery
unplug the power adapter
press and hold power button for 30secs
put the battery back in
plug in the power adapter
power on the computer
if same issue will happen then you need a battery replacement.
May 21, 2010 | E-Machines M5310 PC Notebook
CAnon indicates low batery even it is full
Clean the battery holder with a pencil eraser, otherwise go for good brand rechargeable battery AA 2700 mAh try it.
Aug 25, 2009 | Canon PowerShot A590 IS Digital Camera
Wii control
Try to reconnect your wii-motes, by using the red button on the wii underneath that front flap where you would put the SD card. and then the other red button on the controller where you put the batteries in. and make sure the batteries are fresh
Aug 16, 2008 | Nintendo Wii Console
The upstage phone wont charge at all
try putting it in the black case that came with it because tht is actually extra battery so put it in there and then charge it :)
Jul 07, 2008 | Sony Ericsson W600i Cellular Phone
ICOM IC-F11
Bad battery, Buy new one on ebay. Carl
May 17, 2007 | ICOM Informatique Icom IC-F11 5W 16ch VHF...
Top iLO Audio Players & Recorders Experts
Jean Sintulaire
Atiq
k24674
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
