Question about Emerson Car Audio & Video
SOURCE: Renault Trafic 1,9 dci 2002
check other fuses and relays and re set fuel cut off switch
Posted on Aug 02, 2008
SOURCE: How do you replace the light bulbs on the dash heater control
u must pull the entire cluster out to replace the bulbs.
Posted on Feb 11, 2009
SOURCE: renault trafic 1.9 dci new turbo but lights on dash still on stop
This is a problem with the onboard management computer. It probably wasn't reset by the mechanic when the new turbo was fitted. You'll need to take it to someone with the correct diagnostic equipment to get this fault erased. Avoid Renault dealerships. They'll charge anything from £80 to £400 to clear an error. Best find someone independent.
Posted on Apr 30, 2009
SOURCE: fitting instructions for the towbar electics on a
Behind the left reversing light is a grommet that you can put the towbar wire through, and just behind this is a large black connector, this has all the wires for the towbar, unfortunately there are several wires of the same colour that do different things, best use a test lamp on each one as you connect them. The indicators are "self monitoring" so you do not need a buzzer or light on the dash to tell you that the trailer is working, when you indicate with the trailer connected the ticking sound of the indicators changes to a pinging sound.
Posted on Sep 14, 2009
SOURCE: RENAULT TRAFIC NOT STARTING WHEN TURNING IGNITION
sounds like a dead battery or a bad connection at the battery
Posted on Oct 27, 2009
Mar 24, 2015 | 2009 Renault Trafic 1.9dCi
May 02, 2014 | 2009 Renault Trafic 1.9dCi
Sep 05, 2012 | Renault Cars & Trucks
Aug 15, 2011 | 2006 Renault 181
Jul 07, 2009 | 2006 Renault 181
Apr 29, 2009 | 2006 Renault 181
Feb 18, 2009 | 2000 Renault 181
Feb 28, 2017 | Emerson SmartSet Dual Alarm AM/FM Clock...
225 people viewed this question
