I just replaced the bulb because I thought that would fix the problem. It is worse now. When the projector displays the image on the screen, it is like there is a duplicate image of the screen offset in pink. The best way to describe it is like a pink shadow to the left of everything.
From your description, it sounds like an alignment problem. There are 3 LCD panels in the projector. Each one displays an exact duplicate image of the others except it's either red, green, or blue. Under normal conditions, the images precisely overlay one another so you get a sharp image. Due to age, heat, or vibration/shock(impact) it would appear that the red LCD panel has shifted a little, giving the "ghosting" effect. You'll have to have the unit repaired by a qualified tech. He'll have the special electronic equipment needed to align the panels properly. Before sending the unit in, try a reset in the menu. Sometimes, the projectors can shift the image electronically, using math algorithms which will try to auto-sharpen the display. Hope I was able to help!---Rick
