My LTF6700FS0 washing machine is giving me a "EF1" error message.
I have a Fridgidaire LTF6700FS0 washer which is giving me a "EF1" error message. I know this is the message for a clogged drain pump, but I need to know if there is a fairly simple way to unclog it. Thanks in advance.
Posted by tora712 on
Anonymous
  • 998 Answers
You could try to help it with a water vac hi hi thumbs up
Posted on Aug 11, 2009
How do I remove the filter on my front loading Affinity LTF6700FS0 to clean it?
Look at this video. The filter is in the black boot the runs from the tub to the pump.
Dec 05, 2012 | Frigidaire ATF6700FS Front Load Washer
Fridgidaire fafs4272lwo door open error
Make sure the latch is not broken on the door. Retry. If this continues contact a professional so the latch and door assembly can be diagnosed. Also check to see if the door is sagging down at all.
Aug 02, 2012 | Frigidaire FAFS4272LW Washer
Bleach will not dispense
Here is a tip that I wrote about the problem I found with my fridgidaire not dispensing fabric softner. Hopefully this will help you out...
Fridgidaire Washing Machine Fabric Softner not going into washer
http://www.fixya.com/support/r5660917-fridgidaire_washing_machine_fabric
heatman101
Aug 20, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
E20 error code fridgidaire washer
A lot of times it is the strainer clogged at the pump. Hope that helps. Tim
Sep 02, 2009 | Frigidaire ATF6000ES Front Load Washer
Beeps, then error blinking in display 'EFO'
The error codes are not shown in the owner's manual. They would be in the technical information for the washer. They are intended for service technicians. The chart of the error codes is shown below. The EF0 is a group code that indicates that one of the faults associated with error codes beginning with "EF" occurred. This group includes EF1, EF2 and EF5 as shown in the chart below. To determine the exact code of the failure, you can use the procedure in the second image to recall the specific code.
If the washer had excessive suds, you can likely drain it after the suds dissipate. Make sure that you are using HE (High Efficiency) detergent in appropriate quantities in the washer.
If the EF5 error occurred, you could have the hot and cold water lines switched on the back of the washer. You could also have a problem with the temperature sensor.
If the EF1 occurred, you likely have a drain problem. Check the drain line for kinks or clogs. To access the drain pump in the washer, you would need to unplug the washer and remove the bottom front service panel. If you access this area, you can check the pump. Be careful. If the washer tub is still full of water, it will drain out through the pump if your pull off any of the hoses to the pump. You can evacuate most of the water from the tub by using a wet/dry shop vacuum. A clog in the pump could be causing a drain problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 29, 2009 | Kenmore Washing Machines
Err 10 message on Fridgidaire front load washer
The E10 error indicates a long fill error meaning the machine thinks it took to long to fill with water.
            We recommend u to check that the drain tube is now stuck to far into the stand pipe and possible causing as siphoning problem, and that the screens on the water valve inlet are cleaned and not slowing the water flow.
             u can hook the drain hose off, forcethe  water through it with a water hose, unclog the stinky mess and  hook it back up again and  work it.. tat woul do..
Plz rate this solution.. thank you..
Apr 08, 2009 | Frigidaire ATF6000ES Front Load Washer
I have a Fridgidaire Front Loader Washer _ Affinity. It has an error message flashing. E10. What does that mean? What do I do to fix it?
I have a Fridgidaire Front Loader Washer _ Affinity that flashed the E10 error code. I also had the problem with the fabric softener dispenser not emptying, and staying full of water. The problem was the cold water filter on the back of the washing machine that was semi-plugged. Cleaned the filter and now works perfectly. My machine is no longer flashing the Error code 10. The dispenser works perfectly.
Oct 05, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Fridgidare Affinity washer door won't open after wash cycle
Try the following site for full information on unlocking Dryer -------
http://www.freepatentsonline.com/4908957.html
Sep 14, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Ddo error on fridgidaire washer
I am having a DDO error on my washer,
what does that mean
Jun 05, 2008 | Frigidaire Washing Machines
Washing Machines Logo
213 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
