Question about HP OfficeJet Pro L7580 InkJet Printer
HP Officejet Pro L7580 ADF will not pick up paper. ADF top roller will not lower to grab paper. During process, ADF mechanism clicks as if it is trying to lower top roller, but ADF top roller will not lower. Rebooting of printer and computer does not resolve problem. Event Log shows ID 49, Event 69552, Printer Event. How do I get the machine to recycle so that the top roller correctly cycles?
Posted by johnthetruck on
Anonymous
    Problem Solver:
  • 8 Answers
You can lift the top of the unit to inspect the rollers. Be careful because the L series the roller can pop off easily and if you're not paying attention to original orientation, can be a pain to put back in.. you press the blueish button to release the pick up assembly. See if any rollers are dusty. If they are, use Isopropyl alcohol (highest % you can find) and a LINT FREE cloth (dryer sheets/coffee filters or something of that nature..) and wipe clean
Hope this helps, I'm honestly doing all this from memory, I used to work for that dept here in Oregon ..
Posted on Sep 08, 2009
Automatic Document Feeder seems tempermental
Sounds to me like you need to clean the ADF feed rollers. You can use a rubber cleaner or HP recommends using water.
Jul 21, 2014 | HP Officejet Pro 8500 Wireless All-In-One...
My HP Officejet Pro L7780 faxes off & on. Motor is running w/in ADF, but the pick assembly does not grab paper
There should be a textured seperator pad, if that's worn out, replace it. Also check the ADF rollers should not be smooth. You may need to just replaced the ADF maintenance kit. It should include the roller assembly and seperator pad.
Jan 17, 2013 | HP Officejet Pro L7780 All-In-One InkJet...
Paper jammed in the ADF and can not pull out or remove.
Required tools... T10 screw driver, cloth, tweezer, water
Remove ADF input tray, open adf door, remove connector, remove T10 screws, lift the adf mechanism, remove the paper, observe why paper got strucked, shoot the problem, clean the mechanism & sensors with cloth, fix the machanism back..Dip cloth in to water sqeeze it, clean adf pick up roller with it. fix all spares back,..Check..
Sep 14, 2011 | HP Officejet Pro L7590 All-in-One InkJet...
HP Officejet Pro LP 7880 feeder does not work, how to fix it?
Step one: Check the paper in the ADF The condition of the paper or the amount of paper loaded in the ADF might prevent the ADF from picking it up and feeding it through the product.
  1. Make sure that no more than 50 sheets of paper are in the ADF input tray.
  2. Make sure the original is not photo paper or carbon paper. These types of originals must be loaded on the scanner glass.
  3. Make sure the original document that is loaded in the ADF meets the following criteria:
    • Free from curls, folds, creases, and tears
    • Does not have staples or clips attached
Step two: Make sure the ADF pick assembly is in good working condition
  1. Remove the document feeder and open the ADF cover.
  2. While lifting the blue-green lever, carefully rotate the pick assembly toward the open ADF cover until it stops.
  3. Examine the pick assembly.
    • Make sure the bottom roller is held firmly in place by the two-catch, which is located to the left and the right of the roller.
    • Make sure the stack stopper, which is located between the top and bottom rollers, fits within the double slots just above the bottom roller. The stack stopper should move freely within the double slots to flow up and down when the whole pick assembly is lifted and lowered into position.
  4. Return the pick assembly to its original position.
  5. When the product is turned on, the top roller will reset to its original position above the separator pad. There will be a gap between the separator pad and the top roller.
  6. If there is no gap between the ADF top roller and the separator pad, press the Power button to turn off the product.
  7. Wait three to five seconds and then press the Power button to turn the product on. The ADF rollers should reset to the correct positions.
  8. Close the ADF cover and replace the document feeder.
Step three: Clean the rollers and separator pad
  3. Lightly dampen a clean, lint-free cloth with distilled water, and then squeeze any excess liquid from it.
  4. Use the damp cloth to wipe any residue off the rollers and the separator pad. If the residue does not come off using distilled water, use isopropyl (rubbing) alcohol on the cloth instead.
  5. Return the pick assembly to its original position.
  6. Close the ADF cover and replace the document feeder.
Step four: Detaching and re-attaching the ADF pick roller assembly If the ADF pick assembly is detached or not connected properly, follow the steps below to resolve the issue. If the ADF pick assembly works well, do not perform these steps.
  1. Press the Power button to turn off the All-in-One.
  2. Remove the document feeder and open the ADF cover.
  3. Press the blue-green ADF-release button to release the ADF rollers from the pick assembly as shown in the figure below (the red arrow is pointing to the ADF release button).
  4. Re-attach the ADF pick rollers by placing the rollers into the roller slot of the ADF pick assembly as shown in the figure below. The red arrows show the gears on the ADF pick assembly aligned on one side. The yellow arrows point to the two-catch notch.
  5. Once the rollers are placed on the two-catch notch, push them in, so that the two-catch clicks into place. The photo below shows a correctly installed ADF pick assembly.
  6. Close the ADF assembly and cover.
  7. Turn the product on and make a copy with the ADF to check that the pick assembly works.
Jul 16, 2010 | HP Officejet Pro L7680 All-In-One Printer
Hp officejet pro L7590 - automatic document feeder will not pick up - how do I fix this problem?
Hi
Check the following
--Check the paper in the ADF (automatic document feeder)
--Make sure the ADF pick assembly is in good working condition
--Remove the document feeder and open the ADF cover.
--While lifting the blue-green lever, carefully rotate the pick assembly toward the open ADF cover until it stops.
--Make sure the bottom roller is held firmly in place by the two-catch, which is located to the left and the right of the roller.
--Clean the rollers and separator pad
Mar 03, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
Automatic document feeder not working
Open the adf and rotate the pick assembly till you hear a click and then take a coin and run it up and down against the separator pad and then see if the adf picks the paper or not.If this does not work try this *# 329 and scroll thru and select adf pick test if that fails its time for you to get the printer replaced or get an upgraded printer
May 29, 2009 | HP Officejet Pro L7650 Printer
My L7580 grabs too many pieces of paper. Instead of one sheet it grabs 4
Time to replace the paper pick rollers located in/near the tray and above on the pick-arm or paper path
May 17, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Feeder tray does not feed during fax
Hp help
Automatic Document Feed (ADF) does not pick up paper. Follow each step, problem seems to be in pick assembly. Prcess took less than 5 minutes with a successful outcome.
Apr 28, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Paper jams when trying to fax or scan document
Check if the ADF backing is tucked under the the ADF frame. You can view here http://h10032.www1.hp.com/ctg/Manual/c00863866.pdf steps 7 & 8 on page 155.
Apr 07, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
HP OfficeJet Pro L7580 InkJet Printer Logo
1,708 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
