Question about Garden
How to adjust speed settings on Supascoota Sprint?
Posted by Denis Hynes on
How to adjust Touch settings for a Sprint slate 8 tablet
Go through Settings / screen or touchpad
you should be able to adjust it.
Feb 07, 2018 | Tablets & eReaders
2011 Triumph Sprint GT high idle
Hey Graham..
Have you had it tuned up lately...if you had the valves adjusted, the intake valves are too tight...if no one has been adjusting your valves.. you might have an air leak..??
Does the engine rpm's "kinda float" around for a few seconds..idling high then settle back to normal..? .. YES. then its a classic symptoms of too tight intake valves.
Jun 28, 2017 | 2012 Triumph Sprint GT
2008 Triumph Sprint ST cuts out for no reason
Hi, Morne and the usual suspects are:
1. Severely discharged or a damaged battery must have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead acid batteries.
2. Faulty alternator/generator and or voltage regulator.
3. Loose or corroded battery terminals and or cables especially the "NEGATIVE" cable, look for loose, corroded, or broken connectors inside the cable harness at "BOTH" ends.
4. Faulty main circuit breaker or ignition switch, check for loose connections and continuity.
5. Faulty system and or ignition relay, check for continuity.
6. Faulty ignition coil, ignition/electronic module.
7. Faulty CKP, CPS, CMP, MAP, TPS, or BAS sensor, corroded, loose or broken wire connector pins/sockets.
8. Throttle cables and or idle speed improperly adjusted hot idle speed should be 950 RPM to 1000 RPM.
9. Faulty neutral, side stand or clutch lever safety switch.
10. Fuel tank empty
11. Fuel tank contaminated with ethanol sludge.
12. Water or dirt in the fuel system, or clogged filter.
13. Restricted, blocked or kinked fuel line.
14. Faulty fuel pump.
15. Faulty pressure regulator.
16. Faulty or clogged fuel injectors.
17. Lean angle switch is faulty or needs adjustment.
For more information about your issue and valuable "FREE" downloads that you need please click on the blue links below. Good luck and have a wonderful day.
955 Sprint cutting out
engine cutting out Problem Solving Tech Forums Messageboard Triumph Torque
Triumph Sprint ST Service Manual
http://www.triumphestore.com/
Triumph Sprint ST Owner Handbook Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jun 21, 2017 | 2008 Triumph Sprint ST
1974 harley davidsin ss sprint 350cc how to adjust vales.
Hi Anonymous, for more information about your question please visit the websites below. Good luck and have nice day.
Clymer Manuals Harley Davidson Sprint Aermacchi 350 On The Lift 250 350 ss...
Jul 01, 2012 | Harley Davidson Motorcycles
How to put numbers into speed dial on a Sprint Rumor Reflex
Go to the contacts list. Hit more. Settings. Speed dial. tap a number and select the contct/phone number combo to call.
(Source: I literally just did this on a customers cell phone in best buy mobile)
Apr 07, 2012 | Cell Phones
2000 Triumph Sprint RS idles high
Sounds to me like one of three possible problems, or some combination of them.
1) Loose or damaged vacuum hose to the MAP sensor. Check all the hoses to your throttle bodies.
2) Bad O2 sensor. Use multimeter to check or take to the dealer (or buy and use Tuneboy.)
3) Throttle Bodies need to be synced. Again, requires trip to dealership
Jun 18, 2017 | 2000 Triumph Sprint RS
How can I adjust the height of the handel bars on my Schwinn Sprint 10-speed?
You have either a nut or a hex nut on the top of the post holding the bar to unscrew, then raise or lower the post to the desired height, then holding it in place, re-tighten the nut or hex nut.
That should be your answer :)
Joe
Aug 30, 2011 | Cycling
My instinct is stuck on the dial pad and speed dial area
I had the same problem, call sprint and tell them the problem and they should exchange it for you, the problem is that the screen colapsed just enough to be touching that area of the phone. Don't go to a sprint store all they will tell you is its not under warranty and insurance should cover it. 100.00. hell no.
Its free replacement if you call sprint......
Aug 01, 2009 | Samsung Instinct Cell Phone
Palm centro won't display pictures
you have to go to the net and go into internet options, select the advanced option and turn picture display mode back on. Sprint deviced call this mode "fast mode", where pictures are not displayed to increase internet speed. Just make sure the setting shows that pictures will be displayed and your good to go.
GOOD LUCK!!!!
Mar 10, 2009 | Sprint Palm Centro Smartphone
Download speeds on mobile centro
Your download speed on Sprint will depend on whether or not you are on Sprint's 3G network or 2.5G network. On Sprint 3G you should get 100kbps or better download (which is more than fast enough for mobile browsing). On 2.5G it will be more like 20-30kpbs. You can tell from the data icon at the top of the screen whether or not you are registered on Sprint's 3G network.
Jun 26, 2008 | Palm Treo 500 Centro
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
