SOURCE: printing blank pages
hi-
You might be having a clogged nozzles, if you want you can try to dismantle and check on the nozzles, heres the link on how to check it just click HERE
Pls rate as fixya if it helps. Thanks!!
SOURCE: canon bjc-85 printer doesn't print anymore
My 1st brand new cartridge and ink tanks did not work. I took them out and put in my other new ink cartridge and ink tanks, and now it works fine.
SOURCE: HP Deskjet F380 won't print
i think the inside printer have dirt or obstacles that blocken the cartridges while printing.
try to clean manually the printer by using powerful air blower,repeatedly.
SOURCE: Printing alignment problem
First thing to try is to remove the power brick (not just the cord the whole brick) from printer for a minute then re insert and try it again. If this doesn't help try uninstalling it then re installing the printer
SOURCE: CX6600 Epson - prints blank pages
If the Nozzle Check Pattern page prints correctly and completely, the problem may lie within your software settings, the interface cable, or your computer.
To remove and install only the Printer Driver for your CX6600, please perform the following steps:
Driver Removal
1. Go to START then SETTINGS and click on CONTROL PANEL ( START and CONTROL PANEL in Win XP) and double-click ADD/REMOVE PROGRAMS.
2. To remove the printer portion select EPSON PRINTER SOFTWARE and click on REMOVE. Ensure the correct printer model is selected on the uninstall utility.
3. Click OK and follow the prompts. If asked to confirm removal of any personal settings or shared files, click YES or OK.
4. Once the components are removed, power off your unit and disconnect the USB cable.
Installation
1. Go to http://support.epson.com
2. Under Welcome to Epson Support click on ALL-IN-ONES and select FLATBED and then your Stylus model name. Under the Drivers & Downloads section select WINDOWS.
3. Download the most current driver for your printer and operating system.
4. Follow prompts through survey and license agreement and downloading will begin. When prompted, choose to SAVE this file; SAVE it to your desktop so it is easy to find.
5. Once download is complete, close your internet browser. To install simply double-click the file you downloaded and follow the prompts.
6. Do not reconnect the unit until the point in the printer driver installation where you are prompted to check that the unit is on and connected to the computer. Installation should complete automatically.
